Old 03-20-2008, 06:48 PM   #1
scapegoat
Looking at a 69 c/10 stepside for a hot rod project... questions before purchase
Hey all, as the title states... I'm looking at a couple of 69's for a hot rod project, lowered, big block, possibly f/i (actually would love to do a turbo diesel for this) slicks, etc etc etc... the usual stuff...
One of the trucks i'm looking at is a 4x4 and the other is 2wd, both in excellent shape with a price difference of about 2k, with the 2wd being more expensive.
As the intention would be to replace the rear end w/ something more suitable for... we'll say 500-600whp, would it really matter which of the two trucks I purchase as the drivetrain and engine will be replaced?
Obviously, the major difference would be in the front suspension between the two trucks, correct? (after the engine and rearend are done) I'd have to swap everything from the 4x4 front end out with a 2wd front end. What about the steering linkage, etc...
both trucks are 100% stock and appear to be in great condition from the images I was given. Both w/ 6cyl and I believe 4 speeds... so the only real difference is the drivetrain
scapegoat is offline   Reply With Quote
Old 03-20-2008, 09:09 PM   #2
streetstar
streetstar's Avatar
Re: Looking at a 69 c/10 stepside for a hot rod project... questions before purchase
It would be easier and possibly cheaper in the long run to start with the 2wd if thats what you want in the end anyway.
A properly rebuilt 12 bolt truck rearend should handle anything you can throw at it power wise within reason -- 5 or 600 hp should be easy (thats unless something is wrong with it, which is why i said it should be properly overhauled before hitting it with 600 hp's at the strip)
On the street, you will probably spin the tires enough that breakeage would not be much of an issue
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 03-20-2008, 09:17 PM   #3
scapegoat
if that is the case then I'd def go for the 2wd. Now... what entails a "properly rebuilt 12 bolt rearend" and where what truck would I get one? unless the 6cyl 2wd truck comes with one?
yes, I am a complete and utter novice when it comes to this... nice big learning experience
Old 03-20-2008, 09:49 PM   #4
68350
68350's Avatar
Nearly all 1/2 chevy trucks had a 12 bolt, with a few exceptions(my dads 68 gmc had a dana 44). Streetstar is talking about have someone who knows rearends completely go through and replace stuff that is worn and/or could cause significant failure of the rearend. a 12 bolt can definitely handle 500-600 horse, though. do you have any pics of the trucks? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 03-20-2008, 09:53 PM   #5
scapegoat
I'll get pics of both up with the guys contact info once I make my purchase
Awesome, I'd def take it to a professional. lol especially since I'm serious about making it reliable at 500-600 ponies.
Though, my major plan is fitting a turbo diesel under the hood...
Old 03-20-2008, 10:36 PM   #6
cdowns
cdowns's Avatar
i'd much rather start with a rear coil suspension that most 2wd have//the 12bolts can be made strong usually for less than $3000 so if you've got it build it then if it blows you can always stepup th a custom 9" or bigger
Old 03-21-2008, 12:52 AM   #7
69halfton
69halfton's Avatar
i think you should buy the 2wd, for all reasons stated about,
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
Last edited by Liz; 03-21-2008 at 02:07 AM. Reason: check the classified areas, no fs wtb wtt etc in the message forums ty
69halfton is offline   Reply With Quote
