Engine n00b
Big weekend planned
Buying the air tools this weekend.
ECE 2/4 premium new fuel tank sender HEI distrib, and fresh plugs and wires. Should be fun. Pics to come. Here's the before: ![]() |
Skinned knuckles
Re: Big weekend planned
Something to look forward to indeed!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) ![]() '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
Engine n00b
a friend told me to do upper and lower ball joints at the same time - good advice... anything else that should be swapped while in the front and rear end?
Good choice. This way you also build up your tool chest.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
Bushings, either new rubber or if you want a little better handling, polyurethane, and grease them well if you don'totherwise they will squeal like a pig (for poly) and check tie rod ends, sway bar end links, pit man arm and steering, just make sure that everything is ready to drive down the highway, and of course, you will need an alignment b4 you drive it much because it will wear your tires irregularly and cause them to go faster than normal
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
