03-21-2008, 12:18 AM | #1 |
Seat belt won't retract
Its the passenger side that wont retract. Is there a way to fix w/o replacing it?
Thanks much.....have fun.....don t. ..... |
03-21-2008, 12:35 AM | #2 |
Re: Seat belt won't retract
Tke it out and spray some wd40 on the metal parts and it will work fine.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
03-21-2008, 02:15 AM | #3 |
The bolt that holds the belt in the bracket is also the adjuster, but you can get it too tight and it won't retract. Once you loose the nut, you will see that the bolt has teeth on the inside, twist the bolt unitl you feel some it resist then tighten the nut. You may have to do it a couple times. It that doesn't work, the spring broke.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) Last edited by TotalChevy1; 03-21-2008 at 02:15 AM. |
03-21-2008, 05:04 AM | #4 |
It is common for the springs to fatigue, and break. Rarely does the lubricating trick work..
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
