03-21-2008, 12:20 AM | #1 |
ART Control Arms and Sway bar - Tie Rod Issue?
Hopefully someone has a similar setup and can tell me if I have an issue. I'm concerned whether the tie rod will clear the top of the sway bar, looks awfully close. Something seems goofy with how high the sway bar attaches to the spindle. Sorry, this is the best pic i had:
03-21-2008, 12:39 AM | #2 |
Re: ART Control Arms and Sway bar - Tie Rod Issue?
I was able to find a different pic angle...arrow pointing to top of sway bar end link.
03-21-2008, 06:38 AM | #3 |
Questionable
I think you meant how high the swaybar attaches to the lower control arm? Either way, I see clearly what you're saying, and being that I'm running the same darn setup, I'm interested also
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-21-2008, 07:31 AM | #4 |
1972 Chevrolet SWB
Can I ask you to try something??
Can you push the back of the upper a frame in towards the frame and leave the frt part of the a frame left pulled out?? What I am trying to help you see is IF your mock up right now had more caster (upper a frame swept rearward) if you would have more clearance?? The first picture I see tells me if your spindle were laid back more instead of leaning forward it would bring the tie rod mount at the spindle UP more giving more clearance. This is just a test to see if you gain more room with more caster. NOTE. Pull the frt of the upper a frame out as far as possible and push the rear in as far as possible and lets see how much room you gain.I know its not gonna be dramatic but you might gain some.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. Last edited by slammed1; 03-21-2008 at 07:32 AM. |
03-21-2008, 05:23 PM | #5 |
i was told by ART that if you order their control arms and bags for the front, the factory swaybar will not work. they make a sway bar that works with the setup. hope this helps
03-21-2008, 06:18 PM | #6 |
That's ART's sway bar ("muscle-bar") in the posted pics.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-21-2008 at 06:19 PM. |
03-21-2008, 06:48 PM | #7 | |
03-21-2008, 06:49 PM | #8 |
03-22-2008, 01:35 AM | #9 |
Questionable
Damnitall, retrospect is a MFer. I just went to the junkyard and bought two swaybars and ordered bushings to boot. More wasted money!!
03-22-2008, 03:13 AM | #10 |
lol
art even tells you the stock swaybar will not work on their website...
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
03-22-2008, 06:08 AM | #11 |
Questionable
i didn't read it! i think i actually got the swaybars before i got the arms, actually.
03-22-2008, 06:10 AM | #12 |
Ok slammed1, I gave it a shot, it bought me a little bit of clearance. Also, I noticed from another pic on the site that the tie rod comes in quite steep to the spindle, so I think I'm probably ok.
I'm still a little concerned with how the end of the sway bar hooks into the end link (doesn't fit flat, meets at around 30 degrees)...so I'd still like to see some pics of how similar setups work. Anyone? |
03-22-2008, 08:05 AM | #13 |
so sell me the bushings and brackets ...
03-22-2008, 08:45 PM | #14 |
Questionable
i would, but selling those alone i'd lose money I bought these (x4), $24, brackets and bushings.
i think i will end up selling both bars, $45 shipped w/OEM brackets but no bushings, $65 shipped with new aftermarket brackets and bushings. oh, and a bump for other pics of ART setups.
