72 chevy C-20 rear end
I have a 72 C-20 with the DANA 60 rear end, I am thinking to change it to a chev 14 bolt. has any body done it?
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Re: 72 chevy C-20 rear end
Moving this over to the pickup forum for you.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
1971 GMC 3/4 ton, 572 CID
I did it on my 71 GMC, the only issue I had was getting the proportioning set correctly. I removed the factory valve and replaced it with an adjustable one.
71 GMC 3/4 572 CID, 1988 GMC 1/2 2006 Saturn Vue "We always have parts left over on a job this size" |
its all about the +6 inches
then there is the shock mount that needs reloacated, and the mount foe the pan hard bar, then there are speedo gears needing swapped out.
Why do you want to swap to the later axle? |
mine was a leaf spring rear,
I tow a trailer and was advised that the 14 bolt is a stronger axle, my truck is also a leaf spring, what about the spring perches do they have to be relocated?
yea, they had to be moved a little on the one I installed, it came out of a 88 burb, it was no big deal to relocate them.
is it a custom built or GM crate 572 in ur truck? won't a Dana 60 Hold up fine? or did you blow it up right away?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Unless you are getting crazy with power, hammering the throttle, or overloading the truck, the dana will probably be just fine.
My daughter blew up my dana 60 when I had the 454 in the truck, I put the 14 bolt in because I had it laying around. My 572 is costom built
