03-21-2008, 07:31 AM | #1 |
"Trucks with Class"
4X4 AT Linkage Set-Complete-Exc
I just took this set off a 71 Chevy---$50 shipped---It is correct & exc.
The linkage adjustor was not loosened, so no parts are missing. No wear on the frame bracket shaft or trans bracket. It even has the spring/tension set still intact. |
03-21-2008, 07:51 AM | #2 |
Re: 4X4 AT Linkage Set-Complete-Exc
Frank I'll take it send me your paypal address thanks Mike
03-21-2008, 05:32 PM | #3 |
not to jack your thread but i have a question is there a difference between the 2 and 4wd set up as that looks like what is on my 2wd and I am having no luck with it at all thanks in advance for any input mike
hav'n fun be'n me |
03-21-2008, 05:42 PM | #4 |
Born Psycho
the rod between the column and the bell crank are different between 2wd and 4wd's. not positive if the bell crank itself is different too but i'm sure Frank will tell us.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-21-2008, 10:35 PM | #5 |
thanks jerry ! any chance the 78 will interchange ?
hav'n fun be'n me |
03-22-2008, 12:31 AM | #6 |
Always on the hunt...
Lots different... see below pic. Cb
03-22-2008, 12:32 AM | #7 |
"Trucks with Class"
They are all a little different.
2wd frame mounts are different from 4wd and sb are different from bb. 4wd rod & bell crank are different. I don't know about the six cyls or later years. Mike, it us yours & PM sent. Thanks, Frank |
