Old 03-21-2008, 11:57 AM   #1
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
buying a 1/2 ton burban.... any tips?
hey all,
i have been wanting to buy a 67 burban for ever.... but i never find em' without needing serious work! i am looking at a 69 with a 67 front clip and 5 lug disc conversion done in the front, but the rear is still a 6 lug. i guess i can settle..
is the rear on a 69 1/2 2wd leaf or coil sprung?
also, i know nothing about these burbs... i had a 74 454 burban but always wanted one of these
i will be going to see it on sunday. any tips to look out for?
what is the rear bed made of? were they all plywood?
where are the comon rust places to look for on a burban?
are they very different from the trucks?
thanks everyone!!
i know i can count on you guys!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-21-2008, 12:14 PM   #2
project 67 sub
project 67 sub's Avatar
Re: buying a 1/2 ton burban.... any tips?
Originally Posted by 72swb_327stroker_? View Post
hey all,
thanks everyone!!
it should be coil sprung just like the 67 burban.
i believe they are made of marine grade plywood and i also believe they all
came with the wood floor but dont hold me to it.
the common places to look for rust woud be around the top of the windshield, rockers, floor, and the bottom of the rear quarter panels.
no they are very simular to the trucks.
and good luck with your potential buy.
project 67 sub is offline   Reply With Quote
Old 03-21-2008, 12:36 PM   #3
72swb_327stroker_?
knuckle buster..
thanks 67 sub!
does anyone make the replacement wood/bed floor?
how hard are the 67 body trim pieces to find?
roof racks?
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 03-21-2008, 01:18 PM   #4
project 67 sub
thanks 67 sub!
roof racks?
not that i know of.
i believe that you can buy it through catalogues like lmc, etc.
i dont know about the roof racks though, maybe someone else can chime in and give you an answer on that one.
Old 03-21-2008, 06:48 PM   #5
Hart_Rod
Hart_Rod's Avatar
The burbs rust pretty much in the same place as the trucks do, rockers, kick panels, heater boxes....
If it's a 2WD, it should be coil springs. Roof racks are hard to come by, but they are out there (usually not cheap if in good shape). I'm redoing a 69 and I have a 70 GMC suburban with factory big block for sale. Check out my links in my signature... Good luck.
Hart_Rod is offline   Reply With Quote
Old 03-21-2008, 07:23 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
The rear gates are usually rusted and are not reproduced.
All the roof racks were dealer installed options. So you can sometimes find them on other vehicles. I've seen the one I have (or very similar) on Blazers and Jeep Wagoneers.
Frizzle Fry is offline   Reply With Quote
Old 03-21-2008, 11:52 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if a clamshell, the upper hatch rots out from the inside out. Lift and shake to listen for rust crumbs.
My burb is from the soggy PNW, and this one leaks water into the vehicle from all the common places, and the wooden floor in back is all still in great shape, so it *shouldn't* be an issue in Cali.
67/68 trim... if you are talking the lower side moulding, will be pretty much impossible to locate. While the doors and fenders will be the same as the trucks... the rest will be VERY hard to locate.
Old 03-22-2008, 12:02 AM   #8
72swb_327stroker_?
knuckle buster..
wow! thanks.... you guys rock!
any other suggestions?
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 03-22-2008, 12:52 AM   #9
Frizzle Fry
Look for rust in the rear floor pan kick-up under the second row seat. The rear tires can throw mud at the back side of that area.
Rear drip rails, if rusted, have to be custom made with a shrinker/stretcher to replace.
They can also rust around the back of the wood floor and where the rear wheel wells seal to the floor.
Good luck and post pics weather you buy it or not!
Old 03-22-2008, 03:50 AM   #10
72swb_327stroker_?
knuckle buster..
i definately will!
i am 95% sure i will buy it. its only 1300 so i figure as a running project, i can't go wrong unless it has horrible rust issues.
thanks again!!!
eric
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 04-01-2008, 04:29 AM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
spare tire well.I have never seen one that was not rusted.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-02-2008, 02:39 AM   #12
Frizzle Fry
I have, but I sold it when I shortened mine
Old 04-02-2008, 03:40 AM   #13
Longhorn Man
Minor surface rust in mine... maybe a pit or two
