Old 03-21-2008, 06:07 PM   #1
Psycho71
Psycho71's Avatar
Gen III Header ???
What headers are you fella's using on your LS motors. We've got the motor on oounts, and in the chassis. We're going to have to do some mod'ing to the passenger side mount adapter to get the a/c compressor to fit, and we're trying to be pro-active and get the headers so we can make sure there will be no clearance issues with those too.
So what headers are y'all using? Any part #'s would also be helpful.
Thanks,
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 03-21-2008, 07:41 PM   #2
BustedTruck
BustedTruck's Avatar
Re: Gen III Header ???
I need to purchase a set also, but I dont want them hanging below the frame. I thinking of making my own or getting some shorties.
BustedTruck is offline   Reply With Quote
Old 03-22-2008, 04:50 AM   #3
TravisH
TravisH's Avatar
I think thorleys just coming out with a set, might want to try there. I've got ctsv manifolds with ECE mounts but they don't fit without persuasion
TravisH is offline   Reply With Quote
Old 03-22-2008, 06:06 AM   #4
shifty
Questionable
shifty's Avatar
stock '98 f-body headers.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-22-2008, 06:26 AM   #5
killer71
killer71's Avatar
headers we used on killer were for a 00 camaro/firebird brand is pacesetters....everything you ever wanted to know is right here
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-22-2008, 07:50 AM   #6
Hart_Rod
Hart_Rod's Avatar
Check here....
http://67-72chevytrucks.com/vboard/s...d.php?t=275768
I'll be posting pictures tomorrow, .
Hart_Rod is offline   Reply With Quote
Old 03-22-2008, 08:52 AM   #7
AMD6769
In my build I did cheap and easy I used corvette manifolds. there true 2 1/2 and sound good w/ maganaflow dual exhuast
AMD6769 is offline   Reply With Quote
Old 03-23-2008, 06:55 AM   #8
Psycho71
Psycho71's Avatar
Thanks fellas.
Jay
