Old 03-22-2008, 12:34 AM   #1
tkeduk8r
tkeduk8r's Avatar
SM465 Speedo gear HELP!!!!
Can someone who has a truck with an SM465 and 3.73 gears tell me what speedo driven gear you have???? I currently have a "J" stamped on mine (it is steel not plastic) and there was a 1.25 reduction unit between the speedocable and the driven gear. The "J" driven gear has 19 teeth. The donor trans came out of a 82 C10 with a 2.73 ring and pinion. I have a trans guy that has all the gears in the world but I cant seem to find the right combo for this swap... This combo will be used with 31x10.5 tires. I also have never seen a steel driven gear either.... Here are some pix of what I have... the numbers stamped on the Stewart Warner reduction box that arent legible are "666E C4" and beneath that are "1.2500 BT"... any help is GREATLY appreciated!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 03-22-2008, 05:32 AM   #2
tkeduk8r
tkeduk8r's Avatar
Re: SM465 Speedo gear HELP!!!!
anyone????
--Mike
Old 03-22-2008, 10:54 PM   #3
tkeduk8r
tkeduk8r's Avatar
ttt... in the hopes someone out there is not getting the 8 inches of snow we are right now...
--Mike
Old 03-22-2008, 11:14 PM   #4
ed2552
ed2552's Avatar
it rle sucks doesn't it? yesterday i was hauling stuff home from an auction in a short sleeved shirt, and now there is 4 in of snow on the ground
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-23-2008, 04:04 PM   #5
tkeduk8r
tkeduk8r's Avatar
ttt
Old 03-23-2008, 11:59 PM   #6
dan42
dan42's Avatar
I have an SM465 with 31" tall tires on my '67 with 3.73's and I plugged the speedo cable directly into the tranny, and it seems to read around 10-15% slow. I will address it when I seriously go through the truck, but for now, it's O.K. by me.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-24-2008, 12:52 AM   #7
tkeduk8r
tkeduk8r's Avatar
you wouldnt happen to be able to pull your driven gear out and check the letter stamped on your driven gear for me would you???? It would be a HUGE help.... thanks in advance!!!
--Mike
