Old 03-22-2008, 02:20 AM   #1
benoit454
Chris
benoit454's Avatar
some before and after emissions removel pics...
Been removing the emission stuff on our 84 recently. I had to rebuild a carb for it and do away with the egr, then came vacuum lines, and so on and so on. The latest was the smog pump and air tubes from the manifolds. Big difference in looks I think.
Here's some pics for you guys.....
BEFORE....
One DURING....
and AFTER...
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-22-2008, 02:57 AM   #2
jermasaurus
jermasaurus's Avatar
Re: some before and after emissions removel pics...
Looks a lot nicer under there. Any other plans?
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 03-22-2008, 03:40 AM   #3
benoit454
Chris
benoit454's Avatar
yea long tubes and duals later on, maybe rebuild and cam or might leave it alone for now. Needs some new valve seals and valve cover gaskets, slight oil leak and oil burn on start up.
DEFINATELY paint underhood or at least I want to.
Chris
GIT R DONE!!!!!!
Old 03-22-2008, 04:57 PM   #4
manimal
manimal's Avatar
Looks better, but I would put a bigger air cleaner on there...14"
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-22-2008, 04:59 PM   #5
Rooster's82
Rooster's82's Avatar
so can anyone tell me why i can see his pics?
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
Old 03-22-2008, 07:26 PM   #6
benoit454
Chris
benoit454's Avatar
you mean can't see my pics????
or why you can?
everybody says bigger air cleaner, well that was lesss then half the price of a cheap big one and I had to have something and not be broke.
Chris
GIT R DONE!!!!!!
Old 03-22-2008, 08:04 PM   #7
Russell
Professional Grade
Russell's Avatar
I think I'd take a can of degreaser to that engine, hose it down at the car wash, and shoot some paint on it, make it look 10x better immediately!
I also agree with the bigger air cleaner, but won't judge ya for trying to save a few bucks
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-22-2008, 10:06 PM   #8
benoit454
Chris
benoit454's Avatar
we already did hose it off after some gunk at the car wash, and that's what you see in the after pics is after gunk and a pressure washing.
Chris
GIT R DONE!!!!!!
Old 03-23-2008, 07:28 AM   #9
andresco50
andresco50's Avatar
Awesome.. did you obtain more HP'S
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 03-23-2008, 07:55 AM   #10
BowTieOgre
Good work man. Im about to do the same to my '80. The forest of hoses is about to be cleared.
Can you send me a shot of your carb linkage?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-23-2008, 08:34 AM   #11
benoit454
Chris
benoit454's Avatar
I can see what I can do about getting a pic later, prob. after easter.
What was you wondering and maybe I can answer it.
I don't think it got more hp but I'm sure it probably did, less darg on the motor not using the smog pump, since it's belt driven, all the parts saved some weight maybe 20-30 lbs or more?
I'd say to take full advantage I need headers and duals lol, since it's manifolds and y pipe into single 3 inch then dual 2.5's out the muffler.
Chris
GIT R DONE!!!!!!
