Old 03-22-2008, 05:19 AM   #1
billsbowtie
billsbowtie's Avatar
manual brakes to power brake change over ?'s
i am changeing manual brakes to power brakes for a friend and have a few ?'s. will the orig. manual master cyl. work with the booster? do i have to change the proportion valve? i got the booster rod to pedal i know it was drifferent. it there anything else i need to know. does anyone know the easiest way to do this? thanks for any help bill
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 03-22-2008, 08:02 AM   #2
GMCMAX
Active Member
GMCMAX's Avatar
Re: manual brakes to power brake change over ?'s
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
easy swap on my 1/2 ton, I just put the booster on and bolted the m/c to it
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 03-22-2008, 07:51 PM   #3
billsbowtie
thanks the only thing i think i need that i don't have is a nes push rod boot for power brakes. did you use the orig push rod?
Old 03-23-2008, 09:55 PM   #4
GMCMAX
Active Member
GMCMAX's Avatar
No, the pushrod from the pedal to the booster is totally different than the pedal to m/c one
Gets More Chicks
Old 03-24-2008, 04:25 AM   #5
billsbowtie
i see i don't know what i was thinking about.
Old 03-31-2008, 08:30 AM   #6
billsbowtie
i got this one installed without any trouble. thanks to the tread from gmcmax.
Old 03-31-2008, 08:31 AM   #7
billsbowtie
couple of pic.s of my friends truck that i put it on.
Old 03-31-2008, 08:33 AM   #8
billsbowtie
Old 03-31-2008, 08:53 AM   #9
ed2552
ed2552's Avatar
Is that an 88-98 Short Step bed? If so, he did a great job blending it in and making it fit
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-31-2008, 10:19 AM   #10
billsbowtie
yes it is it was like that when he traded for it.
Old 04-01-2008, 07:42 AM   #11
GMCMAX
Active Member
GMCMAX's Avatar
Looks great
Gets More Chicks
