power brakes
Have looked on FAQ and no help yet. Replaced std brake mc and went to a power booster with a new mc, and at the same time added rear disc. Install went well and bled the brakes first with a vacuum bleed system and then went to all four corners and got great pedal. Started truck and have no pedal at all. No brakes goes right to the floor. Shut truck off, two quick pumps and solid pedal again. I do get red brake light on at bottom of pedal stroke with engine running. What am I missing here.
#2 | |
Gone to greener pastures
![]() Join Date: May 2007
Re: power brakes
Brake fluid is cheap; wrecks cost money.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Active Member
![]() Join Date: Jul 2007
Re: power brakes
If after you rebleed and it still acts up, replace the master cylinder again. Especially if you bought at a "fast food" auto parts store. They're not made like they used to.
I had to replace mine several times on one of my newer vehicles before finding a good one. Did the same thing you're describing. It's a PITA, but it's better than slamming into someone... |
