03-22-2008, 11:26 AM | #1 |
Did Junction Blocks Come Stock ???
New guy here again...full of questions...I don't have a '63 wiring diagram right now and was wondering if junction blocks were part of the original engine compartment wiring? I plan to get the Classic Update kit soon, but was trying to do some research ahead of time. And yes, this truck has all sorts of rigged wiring BS.
TimC63 |
03-22-2008, 05:22 PM | #2 |
Re: Did Junction Blocks Come Stock ???
can't tell from the pic, what wiring is running through there, from what I can see, it doesn't look stock
CHEVY ONLY |
03-22-2008, 07:00 PM | #3 |
Are you talking about the shunt resistor, that was typically mounted on the firewall to the driver side of the distributor? If so, yes they did come stock, otherwise I am not aware of a junction block as standard or optional equipment on the 60'-'66 Chevy trucks.
03-22-2008, 09:07 PM | #4 |
The junction/terminal block I have is identical to the below picture from JEG'S.
The wiring is really a mess; if I recall, the junction block is powered directly off the battery which then has a small wire going from that terminal to the other (maybe a fusible link, I hope) and that terminal feeds the starter and fuse block. Sounds janky and non-stock right?
TimC63 Last edited by TimC63; 03-22-2008 at 09:08 PM. |
