Old 03-22-2008, 08:13 PM   #1
rick0312
rick0312's Avatar
Fel pro oil pan gasket?
Hey guys,
I have a new GM crate motor and was thinking of replacing the 4 piece oil pan gasket with the one piece fel-pro type. Since the motor is out of the truck I figure this is the time to do it. do you think this is a good idea or should I stay with the new 4 piece gasket that GM installed?...thanks rick
rick0312 is offline   Reply With Quote
Old 03-22-2008, 08:16 PM   #2
cdowns
cdowns's Avatar
Re: Fel pro oil pan gasket?
the one piece is well worth the time and money to install
Old 03-22-2008, 08:27 PM   #3
rick0312
rick0312's Avatar
i hear I'll need longer bolts to install the fel pro gasket?
Old 03-22-2008, 09:30 PM   #4
mnunn454
mnunn454's Avatar
I used the same bolts. No need to get longer ones. I agree with above. After doing everything right and still dealing with chronic leak problems I'll never use a 4 piece gasket again.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 03-22-2008, 11:17 PM   #5
cruiserman
I like using studs, too. It makes installing the pan that much easier.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 03-22-2008, 11:30 PM   #6
Billla
Billla's Avatar
Anyone know if they're including these in their full engine gasket kits yet?
I have to admit - I've NEVER had the old-style gasket setup leak for me
Billla is offline   Reply With Quote
Old 03-22-2008, 11:47 PM   #7
bull1kevin
all the Fel pro 1 piece pan gaskets i've bought came with new bolts because they are longer due to the new gasket thickness. They are definatly worth it!
67 short step,bbc,turbo400,drum,unfinished
bull1kevin is offline   Reply With Quote
Old 03-23-2008, 12:14 AM   #8
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I have used several - none came with new bolts tho.
I ended up buying longer sst bolts
They all worked very well.
I understand the MR. Gasket 1 pc works even better.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-23-2008, 12:53 AM   #9
dave2953
Dave's not here, man
dave2953's Avatar
The one I use didn't come with longer bolts, but the factory bolts worked fine. No leaks for nearly 2 years now.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-23-2008, 04:19 AM   #10
wibilly
wibilly's Avatar
i bought one for the crate moter in my vette when i bought it and tore it down for inspection but couldn't use it. crate moter blocks are cut out for dipsticks on both sides unless felpro makes a 1 piece just for crate moters your sol on the 1 piece. i had to buy 2 pan gasket sets to make 1
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-23-2008, 05:55 AM   #11
rick0312
rick0312's Avatar
I was worried about that too, but it looks like if you purchase one for a 1975 and above SBC it has both sides.
Old 03-23-2008, 10:26 AM   #12
hvychve
To The Levy
hvychve's Avatar
newer is better, I wouldnt use another type of oil pan gasket, big or small block, so much easier to install and better sealing..... go with one piece..... no hesitation should be needed
hvychve is offline   Reply With Quote
Old 03-23-2008, 10:37 AM   #13
firedog
firedog's Avatar
i just freshend up a 305 and i put on a one pc purchased at advanced for $22 and it came with new bolts wouldnt do it any other way
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 03-23-2008, 10:48 AM   #14
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
absoluetly DO IT!!!!
re-usable, they have crush sleeves in each corner so you can't over torque the gasket and create leaks... plus yes they come with the bolts. and the kit comes with those handy little plastic anti-gravitational do-dads that hold the gasket in place upside down(wow)...
plus its one piece! where can you go wrong?
while you are at it get the rubber re-usable valve cover gaskets too, $15 bucks=worth every penny!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-23-2008, 05:55 PM   #15
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Anyone take it off and reinstall with out any leaks? What did you do about the corners where the silicone goes?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-23-2008, 06:10 PM   #16
Long Roof
Old School, New Style
Long Roof's Avatar
I have had great luck with these gaskets. I put one on a 87 4x4 burb in the driveway and I put one on my 72 Jimmy. A little pricey but I love them. Both of mine came with new bolts. I have not reused a gasket but I don't see why you couldn't. I did not use any silicone on either of my installs. I also have a rubber gasket on my turbo 350 auto in the Jimmy and yes I have had that off and on a few times without problems.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 03-23-2008, 07:26 PM   #17
wibilly
wibilly's Avatar
thats cool that they have one for the crate blocks now and it looks like the price has come way down the last one i got was close to $70
Old 03-23-2008, 09:49 PM   #18
72swb_327stroker_?
knuckle buster..
yeah i have re-used my gasket... i swapped out a custom oil pan that i had made with a kickout 7qt moroso oil pan....for the silicone you just peel it off, dry the gasket and re-use it. worth its weight in gold!
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 03-24-2008, 06:24 AM   #19
rick0312
rick0312's Avatar
Cost $33.00 at national auto parts. Went to autozone first.... the computer said they had it for $23.00, but the kid behind the counter could not find it or did not care to find it. Anyway, it cost me 10 bucks more at National. Check out the install.
