Old 03-22-2008, 10:20 PM   #1
collin86
installing my first 4 link w/coilovers
ok so im getting ready to start doing my rear suspension. i have a comp enginering magnum 4 link kit, diagnal link, all poly rod ends. im going to box the frame and build a small c notch. im looking to get about 6" drop in the rear or so.
im looking for any tips to make this go as smooth as possible. i have never installed a 4 link before, but i know how they work and i have done my homework
pics soon
collin86 is offline   Reply With Quote
Old 03-22-2008, 10:32 PM   #2
abadsvt
abadsvt's Avatar
Re: installing my first 4 link w/coilovers
Well set your frame up at your ride height and then install you 4 link so that bars are parrelle to the ground. It might be benificial for you to make some sort of jig to hold the rear end so it doesn't move when setting everything up. That way everything is centered when done. Also it is better to mount the long perpendicular links as far as you can towards the wheels. Imagine if you are standing up with both of your legs close together and someone bumps you. Most likely you will fall over because you don't have a good stance but if you were to spread your legs out you have more stability and probably not fall over. The similiar analogy with setting up the 4 links. I know that sometimes you have things in you way or what not so just do the best you can and i am sure it will be fine. Good luck and do a search to look at some pics.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-22-2008, 10:44 PM   #3
collin86
thanks. i have been looking at pics for weeks now and just burning all the info into my head. thats a good thought on going wide...i never thought of that. thats exactly why i made this thread
Old 03-23-2008, 02:46 AM   #4
AirMale
AirMale's Avatar
Are you back-halfing or using a cross member?
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 03-23-2008, 03:22 AM   #5
collin86
im using a cross member
Old 03-23-2008, 03:30 AM   #6
AirMale
AirMale's Avatar
2X3 cross member will go under the frame rails and there is plenty of adjustments for ride height and tire size.
86 SWB 9.0 LITER
Old 03-23-2008, 04:25 AM   #7
collin86
can i get a 6" drop in the rear if i notch the frame the same way same way as you. i have the comp enginering kit, so the front mounting brackets are different, i have to come up with a good way to mount them. also what does the back of your truck weigh, i need to know what spring rates on qa1 coilovers to get for ride height
Old 03-23-2008, 05:18 AM   #8
jlaird
jlaird's Avatar
like abadsvt was saying, try to mount the 4link on the outside of the framerails.
Abadsvt, I always wanted to ask you, your username...svt as in F@RD??
jlaird is offline   Reply With Quote
Old 03-23-2008, 06:32 AM   #9
abadsvt
abadsvt's Avatar
Shhhhhhh. I don't think were aloud to say the F word. Yes i used to own a SVT Contour when i was 17 and i have always kept the name. Not sure why though
Josh
(Project truck)
Old 03-23-2008, 05:47 PM   #10
AirMale
AirMale's Avatar
If you run a fuel cell in the rear of the bed, 175# spring works well. If not use 150# or 160#.
86 SWB 9.0 LITER
Old 03-23-2008, 07:23 PM   #11
collin86
i cant run the links on the outside my tires are to big.
175# spring sounds good...what lenghth shock?
Old 03-23-2008, 08:38 PM   #12
AirMale
AirMale's Avatar
http://cgi.ebay.com/ebaymotors/QA1-C...spagenameZWDVW
Get the shocks with a 12" ride height with 10-14" travel.
86 SWB 9.0 LITER
Old 03-23-2008, 11:43 PM   #13
collin86
ok so 12" ride height shocks with 10-14" of travel and 170# spring.
will that be a good combo for the street? and will that allow for plenty of travel with a 6" drop rear?
Old 03-23-2008, 11:46 PM   #14
AirMale
AirMale's Avatar
Great on the street. Nice and soft. Now I need to bag the front to get a better ride.
86 SWB 9.0 LITER
Old 03-24-2008, 01:58 AM   #15
collin86
yeah a 4 link in the back with coilovers and air bags up front...that would be sweet
Old 03-24-2008, 02:45 AM   #16
collin86
is there anyone doing it
Old 03-24-2008, 09:44 AM   #17
nwmod39
nwmod39's Avatar
collin i am from spokane as well. i would like to possibly meet up with you and take a look at your project. live near francis and crestline.
steve
1980 c-10: under destruction
http://photobucket.com/albums/c372/nwmod39/
nwmod39 is offline   Reply With Quote
Old 03-25-2008, 12:54 AM   #18
leftcoast66
leftcoast66's Avatar
HAHA, i'm in spokane too, lemme know if you need help, after this week should have my car back. I'm up at gonzaga.
leftcoast66 is offline   Reply With Quote
Old 03-25-2008, 01:25 AM   #19
collin86
seems everyone is from WA...anyone from spokane have a 4 link on their truck. it would help if i could see one up close
1986 swb...soon to be some weird pro touring look..but better
92 jeep cherokee.... crawler
Old 03-25-2008, 09:18 AM   #20
collin86
ok so with these shocks and 175# springs will i be able to get 5-7" of drop in the rear
Old 03-25-2008, 03:41 PM   #21
AirMale
AirMale's Avatar
The mounts make it very adjustable. I am a little concerned about how you will integrate the front link brackets to a crossmember, CAchassis works are specifically designed for this.
86 SWB 9.0 LITER
Old 03-25-2008, 07:25 PM   #22
collin86
that is really the only thing i am worried about right now too. im still waiting on my 2x3" crossmember. i think i will either try and fab something up, or just order different front link brackets that are notched
Old 03-25-2008, 08:42 PM   #23
AirMale
AirMale's Avatar
I HIGHLY reccomed the Chassisworks 4 link with poly bushings
http://www.cachassisworks.com
BULLETPROOF!
86 SWB 9.0 LITER
Old 03-26-2008, 05:06 AM   #24
collin86
yeah im getting poly bushings for sure. i already have the comp enginering magnum 4 link so im gonna stick with it, but im gonna get different front link brackets
Old 03-26-2008, 12:05 PM   #25
leftcoast66
Sorry my truck is in seattle and I screwed up on the 4 link so haha, means its backhalf time when school gets out and before my lease starts here in spokane for a house.
Lemme know I've got a really good document about building 4 links and such from over on another forum. In depth about the do's and don'ts and why of it all.
