Old 10-28-2002, 10:14 PM   #1
steves1967
steves1967's Avatar
98 Yukon- 350 engine???
I've got a 98 Yukon with the vortec V-8. I want to pull this motor and put it in my 71 long bed, how can I keep the fuel injection? Does anyone make a wiring harness to utilize the stock F.I. set-up? I assume I would be able to reuse the stock computer and maybe get the tranny adapted to work without the transfer case...
Thanks alot,
Steve
steves1967 is offline   Reply With Quote
Old 10-31-2002, 04:03 AM   #2
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
your probably going to have to pull the entire wireing harness(cheap) or call painless wiring $$ and see what they have..
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 11-14-2002, 03:26 PM   #3
Tom
driving is in my blood
Tom's Avatar
painless wiring has a kit, or else the entire wiring harness from the yukon is coming out. You'll also need the computer re-programed so it thinks you have a manual tranny. You'll need the exaust manifolds for the EGR and the oxygen sensors, maybe the y-pipe too. You'll have to swap in the fuel system too, including the fuel tank and in-tank pump. The ignition is computer controled. Its a hard swap, but worth it.
Old 12-01-2002, 12:18 PM   #4
Terry'sToy
It's true you'll need all the above but you can run headers and just get the appropriate codes deleted from the computer when you get the computer reflashed. A.I.R and EGR can be removed and well as the second O2 sensor all at the same time you have the computer set up for your trans etc.
Terry
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's
Terry'sToy is offline   Reply With Quote
