Old 03-23-2008, 01:15 AM   #1
chev74
Addicted to Chevy
chev74's Avatar
blower switch diagram?
Im having trouble with my heater blower switch- basically it doesnt work. I was wondering if i could get someone to post a wiring diagram for it or help me dissolve this problem.
I have a non AC truck; the switch has 4 prongs on the back of it, but the harness only has three receptors
Im not getting any juice (i dont think) to the harness
chev74 is offline   Reply With Quote
Old 03-23-2008, 01:17 AM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: blower switch diagram?
This is what the harness looks like that plugs into the switch- am i missing a female spade i one of these holes?
Old 03-23-2008, 02:01 AM   #3
BoeJaker1976
These came out of a 76 wiring -10. Im pretty sure they are wired the same. But i hope this helps!
1976 Red chevy steppy,
Proud service member, US ARMY
15Y, AH-64D Apache Longbow Armament, Avionics, Electronics technician
BoeJaker1976 is offline   Reply With Quote
Old 03-23-2008, 02:07 AM   #4
chev74
Addicted to Chevy
chev74's Avatar
ill se what i can do- THANKS for the quick response
Old 03-23-2008, 02:13 AM   #5
chev74
Addicted to Chevy
chev74's Avatar
ALSO- what is the best way to remove the cables that direct the airflow/temp? they seem to be riveted on, or have some clip holding them
Old 03-23-2008, 05:48 AM   #6
BoeJaker1976
Are you talking about the cable that goes to the heater core flap on the back of the control? Well, if you are, then all you do is take some needle nose pliers, and pull up on that little china hat looking deal, but dont bent it, because you can re use those
Old 03-23-2008, 11:20 PM   #7
chev74
Addicted to Chevy
chev74's Avatar
got it done. They were a pain to get off but i flattened them back out with pliers and reused them- THANKS
