Old 03-23-2008, 02:41 AM   #1
68whitechevy
Frame mounted Master cylinder
Is anybody on here running a frame mounted master cylinder? I'm have been thinking about trying to do this and wondering if anybody has tried it already.
Oh and with or without power?
68whitechevy is offline   Reply With Quote
Old 03-24-2008, 07:17 PM   #2
68whitechevy
Re: Frame mounted Master cylinder
one more time
Old 03-25-2008, 05:30 AM   #3
abadsvt
abadsvt's Avatar
I am pretty sure there isn't enough room to run one. The stock 67-72 trucks don't have enough of a factory body drop to use one. Now i am not 100% sure it can't be done but everything i have looked at wouldn't work.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-25-2008, 05:43 AM   #4
68whitechevy
thanks for the thought. I havent looked a whole lot into it. Just thinking it may be nice to do.
Old 03-25-2008, 09:29 PM   #5
stunna
actually you can mount a hydraboost system on the frame. No limit engineering will make a kit that is bolt in for it. it is pricey!
stunna is offline   Reply With Quote
Old 03-26-2008, 05:41 AM   #6
68whitechevy
have you used one of these kits?
Old 03-26-2008, 09:09 PM   #7
stunna
no i haven't, but i hae been told by more than one brake manufacturer or retailer that it can be done. i have talked to no limit on several occasions about it and they have done them. the guy you need to talk to is Michael
Old 03-26-2008, 09:20 PM   #8
68whitechevy
thanks ill check them out
