Old 03-23-2008, 04:36 AM   #1
rscam
Truck leans to left. Whats wrong?
69 GMC. Leaf rear, shortbed. It leans about 1.25 inches in the rear and .50 inches in the front. I am assuming the leaf spring on that side is shot. If the rear was level I imagine it would help the .50 inch in the front also. Any ideas?
rscam is offline   Reply With Quote
Old 03-23-2008, 05:03 AM   #2
cdowns
cdowns's Avatar
Re: Truck leans to left. Whats wrong?
check for bad rotted cab mounts also make sure all the tires are the same size check for obvious kinks or bends in the frame or spring mounts from accident damage if all that is good next step would be new springs
Old 03-23-2008, 05:47 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
It's tired and is looking for a wall to lean on.
piecesparts is offline   Reply With Quote
Old 03-23-2008, 06:13 AM   #4
jpabberton
madcow
jpabberton's Avatar
Maybe its a Democrat...
1970 SWB 4x4
350 4 speed
Factory AC
jpabberton is offline   Reply With Quote
Old 03-23-2008, 06:26 AM   #5
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Keep in mind a weak rear spring will make the opposite side frt spring seem stronger. Imagine a truck with a weak right rear leaf and you will notice the left frt sitting higher generally than the right frt.Also same scenario,a weak right frt coil can make the left rear leaf measure higher than the right rear and so forth. Measuring all 4 corners on LEVEL ground like a garage floor will help you determine which corner may be at fault.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-23-2008, 06:51 AM   #6
Psycho71
Psycho71's Avatar
Might be "set-up" for oval racing?
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 03-23-2008, 08:28 AM   #7
rod86
great southern land
rod86's Avatar
hmmms my 86 has the same problem... no rusted cab/tray mounts so it must be tired springs...
rod86 is offline   Reply With Quote
