Old 03-23-2008, 04:03 PM   #1
gmc67swb
gmc67swb's Avatar
traction bars
The bars are built by Calvert Racing,was just wondering if anyone has ever used them and how good they are,suppose to stop wheel hopping and axel wrap,appreciate any info....http://www.calvertracing.com/ here's the web page if you want to see them.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 03-23-2008, 05:02 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: traction bars
Check Site Link. Says It Can Not Be Found.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-23-2008, 05:07 PM   #3
70cst
70cst's Avatar
Re: traction bars
Try this.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-23-2008, 05:42 PM   #4
gmc67swb
gmc67swb's Avatar
Re: traction bars
sorry about the link try this....
Old 03-23-2008, 05:55 PM   #5
Re: traction bars
If they work at all (I`m sure they do) then they`ll stop wheel hop and the wheels will hook-up better.
Old 03-23-2008, 08:23 PM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: traction bars
Have you ever thought about converting your leafs to trailing arms? It would be a bolt in. It would also improve handling/ride and eliminate the the need for traction bars.
Just a thought, Tom
Tom Vogel is offline   Reply With Quote
Old 03-23-2008, 10:30 PM   #7
bucky_21_7
bucky_21_7's Avatar
Re: traction bars
If your gonna go threw all that work to change over to trailing arms you could build yourself a set of lader bars. Or be like me and leave the leafs in a build a set of ladder bars and have both.
bucky_21_7 is offline   Reply With Quote
Old 03-24-2008, 12:24 AM   #8
SCOTI
SCOTI's Avatar
Re: traction bars
Effectively.... OE trailing arms are ladder bars that can be bolted in (albeit w/a bunch of work) so they're a good alternative for those w/o fabricating capabilities or equipment. Leaves & ladder-bars? How do you manage this w/o suspension bind when driving around?
Calverts traction-bars (aka Cal-Tracs) are in many <10.00 1320 cars so they do work. Will they work for you? That depends on what the current set-up is, what tuning has been done, & what gains you're expecting.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
