03-23-2008, 04:38 PM | #1 |
what master cylinder? help needed
hey guys, its coming time to start the brakes, and i need some advice on a master cylinder and prop. valve. 68' cab with stock swing petals, 71' 1/2 ton 12 bolt posie rear with stock drum set up, late 70's camero disc front set up. total truck weight 2500 lbs. NON power brakes. i need a m/c & prop. valve that will work with this set-up. also the outside of the firewall is 1/4-3/8 inch thicker, so i will need to some how accomodate the rod being a little short. can anyone help or direct me on this? thanks, pkj
03-23-2008, 05:02 PM | #2 |
Nothing to see here.....
Re: what master cylinder? help needed
71-72 master cylinder and a stock 71-72 prop valve or a CPP PV-1 prop valve. you'll have to do a bit of brake line bending to get the tubes in line with the orifices (sp) but that's the only hassle.
I'm running a NON power booster setup on mine as well. works like a charm. here's my setup: http://www.67-72chevytrucks.com/vboa...d.php?t=284384
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
03-23-2008, 07:33 PM | #3 |
thanks man. question on the 71' m/c; did you buy a 1/2 or 3/4 ton m/c? pkj
03-23-2008, 07:40 PM | #4 |
its all about the +6 inches
With the smaller front brakes, I would go with a 71/72 master, the stock 67 - 70 distribution valve (instead of the stock proportioning valve) and get an adjustable proportioning valve and fine tune it that way.
For the added thickness of the firewall, you may be able to adjust that out with the stock pushrod. If you already have the lines run for your brakes, I would stick with what ever model your truck ir (20 verses 10 series) The lines are hooked up backwards on the master on a 3/4 ton verses a 1/2 ton. |
