Old 03-23-2008, 05:42 PM   #1
ibad57
ibad57's Avatar
Shavin door handels
Im looking for good thread with info on shaving the door handels
need link to silinode required to trip latch how many pounds required?
pics of setup would help a lot
sheetmetal patches to weld in and supplyer
I looked thru Faq: but may have misssed it
we need a sticky on the subject if there is not one there.
thanks for any help on the info
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 03-23-2008, 06:07 PM   #2
Sammy
Re: Shavin door handels
As far as I know there isn't any. My doors are shaved. I have the kit to install. I've heard 20 lb -45 lbs?? Biggest worry is how & where to mount to get a straight pull. S/M patches are on evilbay.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-23-2008, 06:10 PM   #3
tbags
tbags's Avatar
For the filler panels check out www.infantirides.com
and for the actuators check :
http://store.summitracing.com/partde...5&autoview=sku
67' C-10 Project Truck
Clinton Township MI
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=287690
tbags is offline   Reply With Quote
Old 03-23-2008, 06:30 PM   #4
Sammy
Presently I use the wing window for entrance. For fear of mounting everything and finding a huge problem. I've rolled the window up & down looking for an idea spot. But not confident. Someone responded told me 6 inches down from the VIN plate using the 8 inches cable extension?? Assuming that as a guide for the place in the door I guess. Just hate to drill holes though the door to find a better spot. Here is a pic of the doors shaved before the truck was on the road. I will monitor any responses you get.
Old 03-23-2008, 06:37 PM   #5
ibad57
ibad57's Avatar
some ware I found this pic i belive is used to pop door manuelly using the factory key
Old 03-23-2008, 06:40 PM   #6
ibad57
ibad57's Avatar
also I plan to use the factory interior pull lock rod as a release to open while window is rolled down. and trunk release remote to trigger the relay on drivers door
Old 03-23-2008, 06:44 PM   #7
Sammy
Another factor to consider is if you go to a one piece window it might disturb the placement too.
Old 03-23-2008, 08:58 PM   #8
Brad
Out of the carpool lane.
Brad's Avatar
Anyone ever install this kit? http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-23-2008, 09:22 PM   #9
ibad57
ibad57's Avatar
Sammy the back of the glass wont change with eather glass the front would .
Old 03-23-2008, 11:33 PM   #10
49studebaker
49studebaker's Avatar
I wouldn't go less than the 45 pound solenoids. I started with 35 pound on the Stude, they soon burnt up. The company I bought them from "autoloc" later upgraded to a heavier solenoid. The stronger the pull, the longer they will last. A light pull may work fine but heat up more which eventually leads to failure. I currently have a set of 50 pounders that I will be installing. I'm tired of replacing them. It will be the third set I've installed on the same truck.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-24-2008, 12:51 AM   #11
Sammy
Hard to think that to trip the latch mech. in the door would take more than 5-10 lbs actual pull strength. I have 40 lb Autoloc's in my kit now, guess thwy will do for starters.
Old 03-24-2008, 01:45 AM   #12
ibad57
ibad57's Avatar
I belive conecting to the right spot on the latch is the trick
If your siliniod must move lots of linkage it come's at a cost of energy
I would like to see pic's of installed setups on our 67-72 models
Old 03-24-2008, 04:11 AM   #13
Sammy
Ttt
Old 03-24-2008, 05:23 AM   #14
Ridgeback
I do not know anything about shaving door handles but I recently got two sets of door popper solenoids in a parts deal and they are for sale. If you are interested check the 67-72 parts for sale forum. Thanks.
Ridgeback is offline   Reply With Quote
Old 03-27-2008, 04:14 PM   #15
ibad57
ibad57's Avatar
Ive checked all post and faq.and no pics or sugestions on silinode placement so I plan on taking pics and posting in the FAQ: when job is compleate
Im sure this has been done to many trucks but we need pic's and sugestions
Old 03-27-2008, 04:33 PM   #16
tommypic
tommypic's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=157669 dont know if its in here but its a good post to keep
tommypic is offline   Reply With Quote
