air box removal ?
Has anyone removed the air box on the front of the cab? Other than the 50,000 spot welds you would need to drill out is there an easier way to remove it?
Thinking of removing mine to get down in there, fix some small rust issues before they get to large and give it all a good coat a rust preventative paint. Any thoughts, ideas, tips?
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited Last edited by Ace in the hole; 03-23-2008 at 07:16 PM. |
That's right, it's Copper!!
Re: air box removal ?
What "air box" are you referring to?
It's actually part of the cab, the air box that is mounted to the cab, it sits under the cowl. The fan motor for the heater mounts to it. It lets in fresh air to the foot vents.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
laying low
![]() Join Date: Mar 2001
Since that panel is spot welded in "a million" places I don't think I would be considering removing it. I would consider using a media blaster or similar to get down into that cowl area and clean it as good as I could then make what repairs are necessary and seal it. If it looks really bad in there you might need to be on the lookout for another cab anyway.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
From what I can see it's not really bad, YET. It does look like there is a lot of surface rust going down into where you can't reach and I do have a couple of pin holes way down low on the side. Kind of behind the foot vent. I was just thinking that I have the cab off right now and might as well fix it rather than just paint the cab and still have an area that may come back to bite me in the future.
What about cutting a hole in the sides in front of the door hinges. Cut it big enough so you can get in there and work. Then when you have everything cleaned up the way you wanted, take the panel you cut out and weld it back into place. Seems to me that'd be easier than drilling a re-welding a ton of spot welds
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
![]() Join Date: Feb 2004
There was a thread on here that showed how to clean it out and paint it, I will try and find it.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Cut and reweld what you cut out.
Thanks guys. I am thinking that may be the best route to. I will probably cut out the section just in front of the door hinge and get to it that way. It's really not that bad yet and now is the time to fix it while I have the cab off.
