03-23-2008, 09:15 PM | #1 |
What's the differences between a A/C and Non A/C Cab?
I am going to be replacing the a/c in my 72. It had a dealer added under-dash system. I want to install a factory in-dash system. Are there any differences in the dash dimensions or is the only difference the holes for the vents? Thanks, Rodney
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
03-23-2008, 09:46 PM | #2 |
Re: What's the differences between a A/C and Non A/C Cab?
I dont think any size difference. I did my truck with vintage air system. it was non air, but i ordered a unit for a factory air truck. It has to do with controls and cables i believe. Also if i am not mistaken, you have adjustable temp and fan control where as some other it is just on or off if you don't use factory controls.
03-23-2008, 10:04 PM | #3 |
Check out this post:
http://67-72chevytrucks.com/vboard/s...ad.php?t=78378
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
03-23-2008, 11:57 PM | #4 |
Thanks NL
