03-24-2008, 03:30 AM | #1 |
350 OLDS in 71
what all do I need to put a 350 OLDS in a 71 c/10? thanks
03-24-2008, 03:49 AM | #2 |
Re: 350 OLDS in 71
sticky tires ,bop tranyif using auto or bell housing if using manual you will need exaust work, fuel lines and som wiring work and of course your moter mounts will need some mods. sounds like alot but not really that hard if your mechanicly inclined
common sense isn't so common anymore |
03-24-2008, 04:09 AM | #3 |
Fabricate till you "puke"
Re: 350 OLDS in 71
Its a direct "weld in fit" I ran a 455 Olds in the early 90's, but the 350 will be the same fit on the bottom. If you already have a good chevy hydro, you can get an adaptor from TCI, or Tran dapt, to bolt the Olds to the trans. As far as mounts, I used the 5.7 deisel stands /mounts from a late 70's c 10(a little drilling/ welding involved). http://community.webshots.com/user/hotrodhorn there is a shot of the 455, but not too much on detail as far as mounts. any ?, I would be glad to try to answer........crazyL just a thought before you get started.....the small pattern chevy converter will not work with the Olds flexplate(balance weight on the flexplate is in the way).
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 03-24-2008 at 04:27 AM. Reason: more info |
03-24-2008, 06:09 PM | #4 |
Re: 350 OLDS in 71
Not sure on the starter location on the Olds 350. But the 455 starter is on the drivers side. Truck battery on the passenger side. I have ran a long cable across the front above the radiator, with the other truck wiring. Thinking of converting to a bed mount battery for weight transfer. Also had to notch the inside of the frame about an inch on both sides for the exhaust. The 350 may not require this. Don't know.
03-24-2008, 08:54 PM | #5 |
fugedaboutit
Re: 350 OLDS in 71
heres a link for a 455 swap.. hope it helps
http://www.v8buick.com/showthread.php?t=91232 if you register you can see pics
Currently truckless Last edited by redhead69; 03-24-2008 at 08:55 PM. |
