Old 03-24-2008, 07:03 AM   #1
5150
C10 Club Tennessee
5150's Avatar
Pics of Firestone Bags installed
I need a pic of the rear bags installed. I need it without the bed on so I can see how the top of the bag is installed to the frame. Firestone has the two studs coming out of the top. I assume I can run my lines coming out of the original hole in the frame that would be used to mount the top of the coil spring.
thanks
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 03-24-2008, 07:12 AM   #2
SCOTI
SCOTI's Avatar
Re: Pics of Firestone Bags installed
Not sure if it's a Firestone but it can be mounted in similar fashion . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-24-2008, 07:24 AM   #3
5150
C10 Club Tennessee
5150's Avatar
I guess I should have clarified that I need a pic from the inside of the frame rail to see how the top two bolts are mounted.
thanks scoti
Bryan
www.gmtruckshow.com
Old 03-24-2008, 07:27 AM   #4
leftcoast66
leftcoast66's Avatar
sorry I don't have picks, but I just drilled two holes through the frame for the studs to fit through, and I believe that is a firestone in that pic.
leftcoast66 is offline   Reply With Quote
Old 03-24-2008, 07:29 AM   #5
5150
C10 Club Tennessee
5150's Avatar
I don't have that cup at the top of mine, so it threw me off.
Bryan
www.gmtruckshow.com
Old 03-24-2008, 09:43 AM   #6
leftcoast66
That's a bag cup, its not attached to the bag itself, its one of the ones for the front, so I'm guessing the owner went and put that on so he doesn't have to drill through the frame.
Old 03-24-2008, 09:54 AM   #7
The Fab Shack
you still have to attach that cup to the frame somehow.. it doesnt look welded either.. so i'm assuming its an s10 style cut with the 1 stud through the middle, with ahole in the frame.
The Fab Shack is offline   Reply With Quote
Old 03-24-2008, 08:29 PM   #8
SCOTI
SCOTI's Avatar
The stud is attached to the 'hat/cup' & that stud would go through the original hole that retained the OE coil spring. This method requires the least amount of drilling.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-25-2008, 12:50 AM   #9
leftcoast66
Yep...
I've never seen an upper front bag mount w/o the stud, my fullsize bag mounts from back in the day had them I know.
