03-24-2008, 07:28 AM | #1 |
new tranny??
Alright when i put my foot in it my tranny does something weird. It shifts but in between the shifts it revvs up, could this be some type of adjustment or what? I hope i dont need a new tranny, any help is appreciated. it is a th350
also when i drive it normally just a smooth accleration it shifts fine. |
03-24-2008, 07:54 AM | #2 |
Fabricate till you "puke"
Re: new tranny??
Drive er easy, till you have the scratch to build one.....kindof sounds to me thats where you are headed....crazyL oops, did a reread, new trans, as in rebuild?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 03-24-2008 at 07:58 AM. |
03-24-2008, 08:02 AM | #3 |
Re: new tranny??
No its not a new trans, but its a later model engine and tranny so i figured it should have a little more life in it but i guess if a rebuild or replacement is in order thats what it takes.
03-25-2008, 11:23 PM | #4 | |
Re: new tranny??
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
03-25-2008, 11:53 PM | #5 |
Son of a gun
Re: new tranny??
Sounds like your modulator is sticking, or you have a vacuum leak going to it. Check for cracked vacuum hoses leading to the trans. It is not a kick down problem, thats not the way that works.
When is the last time you changed your fluid and filter?
Bill BEATERS ARE NEATER |
03-26-2008, 10:25 PM | #6 |
Re: new tranny??
Alright, its been awhile since the fluid was changed. If i want to adjust the kickdown how do i do that?
03-26-2008, 11:05 PM | #7 |
Son of a gun
Re: new tranny??
The kick down down shifts the trans to 2nd gear when you stomp the gas, I don't think that is your problem, but look on the driver's side of your engine, behind the carb. There will be a bolt going through a long slot in a plastic base, with a cable running through it. loosen the bolt and slide the cable foward or backward until you are happy with the performance.
03-26-2008, 11:13 PM | #8 |
Re: new tranny??
cool thanks. And also i was thinking (seeing as though i'm at school and bored as hell) how hard would it be to replace the modulator on the tranny?
