Old 03-24-2008, 10:58 AM   #1
bluboti
Cool Back end thud
Every time I turn a corner, left or right, there is always an annoying thud. It sounds like the tailgate sliding but I have taken off the gate and all of the hardware that belongs to it. Its always done it even when my Dad bought it brand new in '69. Just wondering if it is somewhat common and what some of you have done about it. Thanks.
bluboti is offline   Reply With Quote
Old 03-24-2008, 11:43 AM   #2
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Re: Back end thud
Do you have a C10 or a C20.
Leaf springs or Coil springs with trailer arms?
Are all the bushings in the back nice and tight?
Do you have a spare tire in the back?
It could be lots of things.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 03-24-2008, 03:23 PM   #3
beautimus
beautimus's Avatar
Re: Back end thud
i new of a guy who had a similar noise, not a thud but more of a pop.
the rear axle was a posi that needed posi additive in it. the rear would seem to bind as he turned at slow speed then it would pop and then free up. after he added the bottle of positraction additive, he went to a big parking lot and he drove in lots of circles and figure eights, to distribute the additive and no more problem. i think its about 5 bucks a bottle at a gm dealer. its might be worth a shot.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 03-24-2008, 03:43 PM   #4
blukangoo
blukangoo's Avatar
Re: Back end thud
Now that you pointed that out, I remembered we had the same problem with our Camaro. We didnīt believe it at first but the additive worked. That would be the easiest thing to try.
My C10 Diary
Our cars:
Old 03-24-2008, 05:50 PM   #5
68 P.O.S.
Re: Back end thud
I have a similar problem, but mine comes from the gas tank.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-24-2008, 08:18 PM   #6
bluboti
Cool Re: Back end thud
It's a C20, leaf springs, no spare tire. Not a posi rear end. It is more of a thunk than a thud. Not the gas tank. Like i said earlier it's been doing it since it was new. Thanks for your ideas.
Old 03-24-2008, 08:25 PM   #7
69halfton
69halfton's Avatar
Re: Back end thud
does the thunk/thud change with speed...I.E slower speeds is louder...or something?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-24-2008, 08:31 PM   #8
bluboti
Re: Back end thud
It seems to do it more on left turns and not as much on right turns. Doesn't really make much difference if it's slow or fast. As far as I can tell, all the mounts and bushings are Ok.
Old 03-24-2008, 09:01 PM   #9
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: Back end thud
Theres always a possibilty your missing a couple teeth on your ring and pinion.... my dads truck was having a loud noise come from the rearend on turns and turns out the ring gears was missing about 4-5 teeth.
ProStreet68SB is offline   Reply With Quote
Old 03-24-2008, 09:04 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Re: Back end thud
Try this to see if you can duplicate it while parked.
Find you the sturdiest friend that you have, preferably a football lineman player type. Have him push on either side of the bed as hard as he can (without doing damage of course)to see if you can hear it. If you can, then you can isolate it.
If you don't hear it then lift one wheel off the ground and repeat by pushing on one side and then the other.
Lastly, have him grab the wheel that's off the ground and pull and/or push as hard as he can to see if you can duplicate it.
I know yours is a rearend noise but I had my son find a worn lower ball joint noise for me on one of my other vehicles by doing this.
68gmsee is offline   Reply With Quote
Old 03-24-2008, 09:06 PM   #11
bluboti
Re: Back end thud
I had the rear end cover off last summer when I had to change a rear axle seal, stuck my fingers in there and to my relief, no shavings! Thanks, though.
Old 03-24-2008, 09:13 PM   #12
bluboti
Re: Back end thud
Thanks for that, I'll give it a whirl. I have tried shaking the bed back and forth while its parked and on the ground. I'll try getting it in the air. To busy this weekend though.
