Help finding seal for wheel
My 87 suburban rear wheel seal went out. I pulled the old one and tried to get a replacement first one they gave me was 8835S this one was to big. Then I tried a 8660S This one was almost the right size but the with in ID is wrong. Mine measures these are close as I do not have calipers od 2.25 width .25 ID 1.5 and I am positve it is a GM 10 bolt but there is no other seal listed???
Re: Help finding seal for wheel
Found out that seal in not sold separate and you have to buy a bearing rebuild kit. This moves the bearing out of the wear marks on the axle which prevents you from having to buy a axle the seal and bearing are all one. Got a slide hammer to pull bearing and bearing broke apart and left bearing race stuck in axle tube. Having to tow to Midas so they can remove race. Darn it!!!!!
