Old 03-25-2008, 01:35 AM   #1
49m
49m's Avatar
Shaving fire wall?
If you shave the fire wall is there any way to run heater?
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 03-25-2008, 01:44 AM   #2
ed2552
ed2552's Avatar
Re: Shaving fire wall?
If you use the Vintage Air Universal kit, All that is sticking through is a 4 fitting polished alum. bulkhead and then you have heat and a/c, i'm not sure about heat only...
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-25-2008, 02:45 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I have that thought in mind as I go forward with the install of a 4 hole bulkhead piece in the corner above the passenger's floorboard.
piecesparts is offline   Reply With Quote
