Old 03-25-2008, 08:07 AM   #1
dan42
dan42's Avatar
changing fuel tank grommet -
I just wanted to let anyone that is planning on changing the fuel tank grommet to be prepared to remove the seat and at least loosen the bolts to the tank. I cut the old one out and discovered that the tank is not centered in the hole in the cab - the wasn't enough room on one side to slide the grommet on. I'm gonna have to pull the seat and loosen the tank so I can get it on. Bottom line, it's not quite the slam dunk I was led to believe.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-25-2008, 08:28 AM   #2
straitnate14
straitnate14's Avatar
Re: changing fuel tank grommet -
I feel your pain on the not so easy but they sound and look easy scams...
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 03-25-2008, 08:34 AM   #3
wzuke
wzuke's Avatar
Mine wasn't centered so I stuck a heavy pipe in it and tweaked it a bit.
wzuke is offline   Reply With Quote
Old 03-25-2008, 08:44 AM   #4
Trent_McAllister
On the positive side, taking out the seat and loosening the tank isn't that hard, just stupid work that takes time.
I would try to move the filler neck around a bit like Wzuke suggested. If you can get some lube like tire bead grease and heat the grommet up warm, it might just slide in yet. Good luck!
My Truck:
1968 C-20 Custom Camper
Trent_McAllister is offline   Reply With Quote
Old 03-25-2008, 05:52 PM   #5
dan42
dan42's Avatar
Thanks - I have to take the seat out anyways - I used dish detergent to try to get it on, but no go. The seat is gonna get redone, and when I do that, I'll fix the grommet, but I would recommend to anyone replacing the grommet, you might be able to do it; just be prepared to take the seat out.
Philippians 4: 6-7
Old 03-25-2008, 06:45 PM   #6
slomotion
Old Duffer
slomotion's Avatar
On my rebuild, the neck wasn't centered so I used my bottle jack handle to torque the filler neck over a little. I couldn't get the grommet to lay flat on the body and discovered that it was a "only fits one way" part. I don't remember exactly, but seems there was a nub on the grommet that had to line up correctly.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
