03-25-2008, 08:20 AM | #1 |
Grand PooBaa Member
Fuel Guage
Ok there is a wire from my gas tank that is connected to a terminal on the fuse block. When I pull this wire and turn on my ignition, it goes to full, when the wire is plugged back in, it goes to empty. Help!!! Gas cost too much not to know when im empty.
03-25-2008, 05:32 PM | #2 |
Re: Fuel Guage
I believe the problem will be with the sending unit in the tank. either the float has a hole in it and does not float anymore or the resistor is burned out. either way you will need to pull the sending unit out of the tank
69 Chevy 4x4 383 Power Last edited by haysonj; 03-25-2008 at 05:33 PM. |
03-25-2008, 09:57 PM | #3 |
Grand PooBaa Member
Re: Fuel Guage
Thanks for the info, unless its a cheap part, then I will live with it until I change to a bed mounted tank.
03-25-2008, 10:46 PM | #4 |
Foolish Mortal
Re: Fuel Guage
03-26-2008, 12:26 AM | #5 |
its all about the +6 inches
Re: Fuel Guage
If it's the float, then it could be dirt cheap. You can afix anything that floats on the rod.. anything that wouldn't be eaten by the gas.
03-26-2008, 07:57 PM | #6 |
Grand PooBaa Member
Re: Fuel Guage
