Old 03-25-2008, 09:17 PM   #1
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Calling all 4/6 drop trucks
I'm getting ready to design my tube frame for my 67, adding c4 front suspension and a 4 link. need help with a coulple of measurements so that i can set my frame ride heigth.
How far is the bottom of your frame off the ground and what size tire do you have?
Also you roll pan guys. Whats the measurement from the bottom of the frame rail to the top edge and the lower edge of the roll pan?
Thanks everyone in advance,
Bryan
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 03-26-2008, 06:56 AM   #2
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Re: Calling all 4/6 drop trucks
Anybody???
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-26-2008, 01:52 PM   #3
see ten
WTB this ad
see ten's Avatar
My truck has a 3.5"/6" drop. This is some info I PMed to another member about the height. It may or may not help you.
I measured from the center of the wheel to the lip of the fender. I thought this would alleviate any tire size/height issues between your vehicle and mine. At ride height I have 14.5". I jacked up the truck to the point that the tires were moving (inward?) and seemed about to come off the ground and got 18.5". A couple more strokes of the jack got the tire off the ground and the tape read 19.25". All these are approximate. I was using a tape and eyeballin it all as best I could. It's possible things could be a smidge one way or the other. I also made some ride height measurements from the truck to the ground. The center of the front bumper 8.25". The center of the first frame xmember from the front 9". The center of the engine/suspension x member 5.25". Again no gauges were used, just a tape and my eyes.
see ten is offline   Reply With Quote
Old 03-26-2008, 09:20 PM   #4
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks a lot for the info see ten. how close to level is the lower staight part of the frame?
My truck is in pieces right now so i cant really measure by the center of the wheel and the fender. and im designing the frame on SDS/2 so i just need from the bottom of the frame to the ground with the tire size.
Thanks a lot for all the help..
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-26-2008, 09:22 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
If your building a frame and 4 link, jsut set it up to where you want it to be
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-27-2008, 02:20 AM   #6
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
I want it to end up being just a bit lower that a truck with a 4/6 drop, so this will give me a good place to start.
Thanks, guys
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-27-2008, 05:00 AM   #7
see ten
WTB this ad
see ten's Avatar
Hmmm,
I'm about this level. Sorry, it's hard to say without knowing if I've got it parked somewhere level.
Old 03-27-2008, 05:33 AM   #8
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
see ten, That is just about how i want my truck to sit.
What size tires are you running?
Can you measure how far your frame is off the ground on concrete, could be measured from even right after the front wheel where the frame staightens out.
Thanks a lot in advance.
Originally Posted by see ten View Post
Hmmm,
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-27-2008, 05:51 AM   #9
see ten
WTB this ad
see ten's Avatar
The rears are 275/50-17 and the fronts are 255/50-17. I can take a meaurement for you but it's going to be tomorrow.
Old 03-27-2008, 06:06 AM   #10
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks see ten your the man
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-27-2008, 11:57 PM   #11
see ten
WTB this ad
see ten's Avatar
Ok, Under the frame at the front of the front cab mount is 7.5" to the concrete. Under the frame at the rear of the rear cab mount is 9" to the concrete.
Old 03-28-2008, 12:37 AM   #12
John Fabris
TOTY 2006
John Fabris's Avatar
My truck is a 4/6 truck with 265-70-15 tires, let me know if you need more mesurements (other then 'see ten's)
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-28-2008, 03:19 AM   #13
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks see ten for the information, i really appricate it.
John fabris , it would be cool to have more just so that i can see the difference, nice to to have the same size tires front and rear, also.
Thanks a lot guys.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-28-2008, 03:19 AM   #14
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
this link might help:
http://67-72chevytrucks.com/vboard/s...d.php?t=276088
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 03-28-2008, 08:26 AM   #15
'67Nate
To answer the roll pan question; The top of the pan is flush with the top of the frame and the bottom is 2" bellow the bottom of the frame. The total thickness of the back of my pan is 5" (making the frame rails aprox. 3"). Hope this is what you were asking for.
If you can't drive safe... Drive fast.
'67Nate is offline   Reply With Quote
Old 03-28-2008, 03:05 PM   #16
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
'67Nate, that is exactly what i needed, you are the man, thanks a lot.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-28-2008, 07:40 PM   #17
John Fabris
TOTY 2006
Here is what I got. My truck is a 4/6 drop kit from ECE (via dropped spindles and springs). My tires are 265/50/15s front and rear.
Starting from the front and working back, bottom of the frame horn (very front) to ground is 7-1/4 inches. Bottom of the frame (under front cab mount) to ground is 5-3/4 inches. Bottome of the frame (under rear cab mount) to ground is 7 inches. Bottom of the frame (end of frame under tailgate) to ground is 15 inches.
Also, ground to bottom middle of front wheelwell is 26 inches, rear wheelwell is 27 inches.
John Fabris
67 C10 SWB
Old 03-28-2008, 09:30 PM   #18
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks John Fabris, i really appricate the measurements, it's exactly what i needed.
Thanks guys
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-29-2008, 03:10 PM   #19
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Hey John Fabris, Do you happen to know what your tire diameter is? I thought it would be close to 29, but with the wheelwell dimension being 26 im not sure.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-29-2008, 06:48 PM   #20
Orange
Licensed to Thrill!
Orange's Avatar
Best web site I ever bookmarked.
http://www.miata.net/garage/tirecalc.html
Probably.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-29-2008, 07:08 PM   #21
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks Orange, that answered my question it's 25.4 in.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-29-2008, 07:09 PM   #22
John Fabris
TOTY 2006
Yup, that is pretty close. I had thought it was around 25 inches...
John Fabris
67 C10 SWB
