454 MAKES IT ROAR
My project for today was to pull my radiator so that I could fit my newly cleaned and painted fan shroud that I bought from hart-rod, and while the rad was out it to would get a good clean and paint. After all the work cleaning sanding and painting it was time to fit but the shroud fixing points would not line up with the rad supports...WTF? it's a bb fan shroud and I assumed naturally that I had a bb radiator on my bb truck but on closer inspection I think it's not the right size rad (see pics)
My radiator measures 31 1/2" is this a bb radiator size? what is the correct size if not? ![]() ![]() So now I have to put the radiator back minus my new shroud but at least this will look better after the restore...."dream on" it leaked like a poxy sive from the bottom it seems cleaning all the gunk off and jet washing has opened up a weak spot somewere. I could get it soldered over here but if it's the wrong size anyway what would be the point? I took a load of before and after shots to post on here this evening of a productive day on my baby...B*****ks
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
![]() Join Date: Jan 2007
Re: Waste of money time & effort
I don't think that's the right shroud. Looks like a later model to me
its all about the +6 inches
Thats not the right rad. The lower neck should angle up instead of straight out. That is for a 73 - 87 or a van.
However, with that being said... I've never seen either aplication not fit width wise. I had a 73 - 87 in my old longhorn and then same one into the GMC, and now I have a van one in my one ton. |
![]() Join Date: Nov 2004
Wrong radiator. A proper 67-72 3 or 4 row radiator (I think big blocks came stock with a 4 row?) should sit snug next to the battery box and use the bolt hole set on the left for the mounting bracket.
Your radiator looks like the 2 row one that came stock in my 67. They didn't have a fan shroud, just the metal thingy on top and used the same mount holes yours is using. It does look like your brackets are proper for a 4 row, they're much wider than the radiator in your truck now. My truck has a 4 row and proper fan shroud, this is how it should look. Notice where my mounting bracket bolts to the core support.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-26-2008 at 12:40 AM. |
454 MAKES IT ROAR
Thanks Andy & 67ChevyRedneck now I have the definative answer on this one..time for a new Radiator.
Thanks also to hyarbour.
MOVE OVER
Get one of these!
http://67-72chevytrucks.com/vboard/s...d.php?t=269234 I would love to have the money for this, of course then you dont need the shroud...
No matter where you are..... There you are... Buckaroo Banzi Last edited by rambler; 03-26-2008 at 01:43 AM. Reason: brain fart |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Looks to me to be a 67 narrow radiator. Wrong radiator for your truck. The upper clamps also look to be for the 4 row radiator, because they are too wide for the radiator you have. Do I need to send you a radiator with the carrier bearing? That would have to go FedEx also.. Let me know. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 03-26-2008 at 02:38 AM. |
![]() Join Date: Jul 2004
Yep, radiator is too narrow, you should be using the outer set of holes - the inner holes are for the 6 banger small radiator.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#9 | |
454 MAKES IT ROAR
Had a look and they seem really good but want to keep that stock look so have placed an order with Wes at Classic Heartbeat. Thanks for all the input and help on this guys it really is much appreciated
member #16
Just a thought. Might not hurt to see if the lower mounts are the wide ones also.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Dave's not here, man
Where are you located in the U.K. I used to live in Norfolk, in a little town called Methwold. My mom was stationed at RAF Lakenheath. Hope you get your radiator problem solved. You'll have to post some pics when you get your new parts installed.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#12 | |
454 MAKES IT ROAR
I will post those pics... thats what I was looking forward to doing today when I had finnished my little resto job then it all went pear shaped. Nigel.
#13 | |
Nothing to see here.....
![]() Join Date: Jun 2007
AND eightbanger, even a day of getting pi$$ed and wasting time and effort on your truck is a good day in my opinion!!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 03-26-2008 at 05:15 AM. |
#14 |
![]() Join Date: Feb 2004
Now you know and knowing is half the battle, GO JOE
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#15 |
F.A.S.T. president
![]() Join Date: Sep 2003
When I switched form the regular to the HD " 4 row BB" radiator I also had to knock out the bottom radiator brackets and get the larger ones and I had to notch out the radiator support for the lower hose clearance. You also will need to cut out the inner fender well for the lower hose clearance. Its not just a bolt in item if the truck did not come with the 4 row from factory.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
#16 |
Can you give a better picture of the shroud?I could be wrong,but that looks like a later shroud from what I can see.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-26-2008 at 04:33 PM. |
#17 | |
454 MAKES IT ROAR
#18 |
That`s not 68-72,either.I think it should work with the right radiator.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-27-2008 at 02:04 AM. |
#19 |
454 MAKES IT ROAR
Great this thing just keeps getting better...so it's official i'm
![]() Thanks for the info S.K
#20 |
454 MAKES IT ROAR
Just an update...took delivery of new and correct size Radiator + 4 new rubber cushions for the supports all supplied by Classic Heartbeat, and it all went in nice and easy the Fan shroud now fits perfectly.
So from this.... ![]() ![]() To this.... ![]() ![]() Cleaned and painted shroud and supports ![]() ![]() ![]() ![]() I love before and after shots...can you tell?
#21 |
Roadtrip!
![]() Join Date: Feb 2003
That looks MUCH better...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#22 |
Looks great!! I didn't see the transmission cooling lines hooked up though.. That realy cleaned up the engine bay, and best of all it will do the job that GM intended it to. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#23 |
![]() Join Date: Apr 2005
Augie - that shroud sure looks a lot better than it did when it left NM,
![]() R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
