Old 03-26-2008, 01:11 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
carb troubles (need help fast)
i have been having problems with the carb on my truck acting up lately and it become very annoying. the truck has been acting up after long drives and i noticed when i pulled off the carb, it had some sand and a coudy gooey substance in the fuel bowl. i put a rebuilt qjet i had laying around on it and it ran fine untill today. it died in an intersection (embarassing). i popped the hood and saw that fuel was all over the carb and intake and fuel was coming out of the accel. pump area. i have taken the carb off and it has the same gunk in this carb. how would i go about stopping this? am i going to have to drop the tank and clean it? how would i clean out the tank?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 03-26-2008, 01:20 AM   #2
ed2552
ed2552's Avatar
Re: carb troubles (need help fast)
put in an inline fuel pump, i am sure it is a plugged filter in your Q-Jet, i have the same problem. Empty the fuel tank and pour some solvent in and swish it around, then pour it out and re-install and fill.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-26-2008, 07:10 PM   #3
crm318
crm318's Avatar
thanks, ill give it a try.
1972 Cheyenne
Old 03-26-2008, 07:12 PM   #4
ed2552
ed2552's Avatar
I meant in line filter, not pump, brain works faster than fingers, but also replace the filter in your Q-Jet.
Old 03-26-2008, 07:15 PM   #5
crm318
crm318's Avatar
i installed an inline filter yesterday and i can see all sorts of junk in it. it runs better though.
1972 Cheyenne
Old 03-26-2008, 07:18 PM   #6
ed2552
ed2552's Avatar
Yeah, then you need to clean out the tank
