03-26-2008, 04:32 AM | #1 |
Active Member
In case there's any doubters re: grounding.
I want to thank all of you who have been telling us, for quite some time, that we need to make sure we have good grounding on these old trucks. I thought mine was ok but found out I was wrong.
I did a search to find out what the rest of you all are doing and decided to do the same. Seems that on these old trucks the rust, dirt and grime builds up on the bolts to the cab, frame and bed and we loose good contact. Here's my experience. A couple of weeks ago I decided to reposition the bed. It was slightly off center. That's when my rear lights decided to do some weird stuff. I had no rear lights and no brake lights with the light switch on. If I turned light switch off, my brakes lights worked. Also license plate light decided not to work either. My rear blinkers stopped working. All this time I thought I had a good grounding on the truck. I did a search to find out what the rest of you all are doing and decided to do the same. Action plan: Went to the local auto parts and bought 3 braided cables and one 19 inch black ground cable. Box of assorted star washers. Ground cable from block to the frame. Ground cable to the radiator support. Ground cable from cab to frame. Ground cable from bed to frame. Made sure I had good clean connections and put star washers on all the ends. All my lights are working and even look brighter. And the bonus, my alternator guage started to work. I had thought I had a bad guage... Last edited by 68gmsee; 03-26-2008 at 04:36 AM. |
03-26-2008, 04:35 AM | #2 |
Re: In case there's any doubters re: grounding.
Cool! I'm probably gonna try that. I'm having a couple of goofy problems in my '67 as well with the instrument panel. Thanks for the heads up.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
03-26-2008, 04:42 AM | #3 |
1971 GMC 3/4 ton, 572 CID
I've seen bad grounds cause the wierdest problems, dash lights blinking with turn signials, radio coming on with brakes, ect. I've learned that when something wierd happens electrialy always check the grounds first.
71 GMC 3/4 572 CID, 1988 GMC 1/2 2006 Saturn Vue "We always have parts left over on a job this size" |
03-26-2008, 04:43 AM | #4 |
Active Member
Man, I hear ya.. I thought I had gremlins in there after I all the weird problems.
03-26-2008, 04:45 AM | #5 |
Great post I'm going to re-wire my 67 this weekend with a new kit from ez wiring none of my gauges currently work so I'm guessing that the grounds are bad now. Or it could be the 10k splices in the harness what a mess. Found a bunch of wires that were exposed with no insulation. lol no heat either. I'm a mazed it never smoked.
03-26-2008, 04:46 AM | #6 |
Active Member
Even if it's not the problem now, it may prevent some in the future (as in my case). It certainly was weird. Worked one week and then go to check and they're all screwed up..
03-26-2008, 04:48 AM | #7 |
"ground cable to the radiator support" ? Where does this one tie into?
72' Custom10 4wd 350: Daily Driver |
03-26-2008, 04:59 AM | #8 |
Well, Whoop-dee-do!
Yep, most weird electrical problems are from poor grounds. Always the first thing to check. Many OE's have gone to the extreme on new trucks- they put battery cable size ground cables from one frame rail to the other- not trusting bolts/ rivets in the crossmembers. Most have gotten away from star washers also- and for good reason. I hate them. In the rust belt, road salt gets into them & you loose connection. A flat shouldered nut with dielectric grease or sealer is best. Same goes for the starter connections.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
03-26-2008, 05:01 AM | #9 | |
Chevy Truck Addict
I will confirm what others have said... My headlights, brake lights, etc are super bright. Nobody can convince me that the lights in these old trucks are just supposed to be dim because they're old... Mine are as bright as any I've seen - old or new.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
03-26-2008, 05:09 AM | #10 |
its all about the +6 inches
take it one step furhter,,, locate the 2 grounding points on the rad core support, remove them, clean them, reinstal, and realize your headlights are brighter. A former member told me when i did hers a few years ago "It's like it's someone else's truck" (first ohio board meet... 03 I think)
03-26-2008, 05:28 AM | #11 |
it never ceases to amaze me the dollars people will throw at a problem while being told repeatedly BAD GROUND and refuse to take a few bolts out and use a piece of sandpaper to establish a good ground to complete a circuit
03-26-2008, 05:32 AM | #12 |
Could my starter be malfunctioning b/c of a bad ground?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-26-2008, 05:49 AM | #13 |
Active Member
03-26-2008, 05:52 AM | #14 |
ed the starter is bolted directly to the engine, which is where the neg cable should be ... odds are, no. Whie it IS possible in theory, I have never heard of nor seen this ever happening.
03-26-2008, 05:53 AM | #15 |
a perfect example the time it took to type and hope for a responce you could have taken a piece of sandpaper and gotten your answer
03-26-2008, 05:57 AM | #16 | |
Active Member
But, since I've been reading the posts about grounding and the recommendations by everyone, it helped me make a quick determination. Longhorn Man's comment about "overkill" on his truck was right on. Can't have enough grounding... |
03-26-2008, 05:57 AM | #17 |
Ok, i guess i deserve that, the thing is just po'ing me. I do need to check my grounds. That is for tomorrow morning since there is no school.
03-26-2008, 06:28 AM | #18 |
nobody mentioned the two ground wires from the firewall to the valve covers//i always went to bigger gauge wire on them and put them to the accessory holes in the back of the heads so to clean up the looks of the engine
03-26-2008, 06:31 AM | #19 |
How about every time you get in your truck you ground yourself to the frame to eliminate all issues?
03-26-2008, 06:55 AM | #20 | |
Personally, i've always thought those were retarded myself. |
03-26-2008, 07:00 AM | #21 |
How about we also ground the camshaft, just to be sure,
03-26-2008, 07:10 AM | #22 |
Go ahead and try that one... get back with me on your results.
03-26-2008, 07:12 AM | #23 |
Well, Whoop-dee-do!
We could go even further... electrolosis. Take a DVOM neg. lead to the battery neg. post, and stick the pos. lead into the coolant in your radiator. You might be surprised what you see. Corrosion isn't the only thing that damages radiators, heater cores, and in extreme cases... blocks.
03-26-2008, 07:15 AM | #24 |
Thx andy, the only time i will ever ground a cam is if i set the old one on the floor, lol
03-26-2008, 08:08 AM | #25 | |
What are you making reference to? You should have 2.1 volts per cell... is that what the surprise is? |
