![]() Join Date: Jan 2006
What ratio manual Tranny?
I am running a stock 350/260hp 3.73 rear gear 31 inch Tires. I want to upgrade to a 4 speed manual tranny. Money being an issue I am most likely to purchase a saginaw. What gearing should i select 1, 2 or 3 ring? I will not be doing any towing or heavy hauling, bascically a weekender and light hauling...thanks
Re: What ratio manual Tranny?
Try to find a super t-10 in the early/mid 70's up to an '82 camaro/firebird. I paid $85 for mine
![]() Might as well go for the one with the lowest first gear ratio either way you go ![]() |
If you are looking for low first, then get a SM465, with a 7.0:1 (appx) first, 2.5 mph in first & 4lo
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
i wouldn't get a saginaw if you plan on doin anything besides granny shiftin. i know they're alot cheaper than a muncie or something else, but if you like slammin gears, you'll blow it up quick. i used to run saginaws in my '69, killed one about every 3 months. switched to a muncie and after a year of beatin on it, its still in there. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
