Old Duffer
![]() Join Date: Mar 2003
Gauge cluster change out
Seems to be the season for instrument changes. I just got this one done, took a ride and useing the GPS the speedo (adjustable) is off a little, but everything else works - much to my surprise!
The dark gauges are what was in it, and the cream color are the new Classic Instrument set I just put in. I think they match the interior a little better. The bottom row of the new set is; Boost/Vacuum (no need for boost, [yet] but had to fill the hole, and vacuum was useful) Air Pressure (Currently the green needle reads the rear bags, if I bag the front the red one will read them) Fuel Guage Oil Pressure The tiny dot in the middle above the temp/volt gauge is a fiber optic high beam indicator. It was an experiment, but it worked out well.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
Re: Gauge cluster change out
I looked at the first pic and thought "Why would anybody change those?". But the new ones look great with the interior. I most always prefer stock, but these look a lot better. Good choice.
![]() Join Date: May 2006
Very nice.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
454 MAKES IT ROAR
Those do look very good I like how you have chosen to lay it out and the Bag gauge looks Ace, when you swap out old Gauges for replacement how do you get the modern electric hookups at the back to work with the printed circut for the origianals or do you have to find replacement gauges that have the same layout on the back so that it will all plug right in.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Between Trucks...
Those look sharp, good job...
Beat it to fit, Paint it to match... ![]() |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Nice Change. Those gauges look sweet.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Old Duffer
Thanks for the kind comments!
Eightbanger, the whole thing is electric (except the vacuum and air pressure). The kit came with new sending units (oil and Water) and the speedo generator. I picked up a Painless wireing harness to simplify the installation, which includes a new harness plug. You push out the sending unit wires from the old harness plug and match them to the new connector plug. Everything was ordered at the same time to be sure everything would hook up correctly.
Tot Roddin'
The new guages really fit the interior in your truck... two thumbs up!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
More Cowbell....
Wow. Those gauges look killer against that dash color.
And I dig the hula-girls.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Its Topless Season!!!!
Wow! That looks awsome........what is the gnob under the choke gnob for?
Old Duffer
Clos69, up here where I live fog is pretty common, and if it's dark and foggy the cab lights make you feel like you're driving around inside a pumpkin. They cut down the vis to the point of being dangerous.
The solution to me was to be able to turn them off if I wanted to, but if they're on the headlight switch you can't do that. I could have mounted a toggle somewhere, but the truck has driving lights too, so that would mean two toggle switches. What I ended up doing was buying another headlight switch and mounting it under the choke knob. There's already a hole in the dash, I just had to drill the bezel. Now, on the second switch the parking light position is cab lights, and all the way out (headlight position) is cab lights and driving lights. I'm in the process of making a factory-looking label to match the rest of them.
Very Good Idea!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#13 |
"GO DAWGS"
Are you looking to get rid of the factory tach cluster.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
#14 |
Nice gauges! They have that cool antique look to them.
1972 Chevy C-10 Fleetside 1979 Pontiac Trans Am 1980 Chevy Camaro (my dads) |
#15 |
Old Duffer
PT'S,
I'm going to hang onto the originals for a while. I've had a couple of PM's about them and told them the same thing. Thanks for the interest.
