03-27-2008, 03:09 AM | #1 |
2,3, or 4 core radiator
I'm going to be buying a new radiator for my 69 1/2 ton with 350 engine.
I was thinking a 4 core would be best, but will it fit? Are 2 core and 4 core interchangeable? I'd like as much info as I can get before making such a big purchase. Thanks for any help. |
03-27-2008, 03:13 AM | #2 |
Re: 2,3, or 4 core radiator
http://67-72chevytrucks.com/vboard/s...d.php?t=284813
Has a bunch of that info.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-27-2008, 04:15 AM | #3 |
The 4 core will work but you will need different mounts. I have a 4 core in mine that I got out of a Chevy van from the 80's. They are the same measurements. You have to do a little trial and error to find a lower radiator hose that will work because it turns up when it comes out of the radiator. I think the diesels vans had them. Maybe some gas burners to but I'm not sure. Some will says its overkill to have a 4 core, But if the price isn't much different what the heck.
03-27-2008, 04:26 AM | #4 |
4 row if its in your budget...specially if you use it to cool your trans..
03-27-2008, 04:34 AM | #5 |
laying low
I put a 4 row in my 69. Wider sadles and upper retainers I picked up from my local Chevy dealer. I figure with the high rpms it will be turning with the 4.11 gear I might can use the bigger radiator.
Be sure to take the measurements with you to be sure you get the correct size the first time.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-27-2008, 04:37 AM | #6 |
Still Just Havin Some Fun!
I ordered one from the local radiator shop for $181. I didn't know I needed new saddles so its not installed yet....
a green one with some stuff done to it.... |
