found a 350 that was bored 30 over boiled, mangafluxed ect. the whole works done on it. came with a balanced crank, balanced pistons(didn't know they even balanced pistons) crane energizer cam and lifters bearings, and piston rings. When i got there he gave me a box with a used started and solenoid, and a serpentine belt system(92 chevy oem). Got it all for 450 bucks
![]() ![]() ![]() ![]() if someone would do me a favor and decrypt the cam info, and tell me the power range and such. lift: intake @ cam 300 @valve 450 exhauset @ cam 300 @valve 450 min rpm 2200 max rpm 5200 valve float 6500 cam timing @ .050 intake opens 7.0 deg btdc closes 31.0 deg abdc max lift 102 deg atdc duration 218 deg exhaust opens 39.0 deg bbdc closes (1.0 deg) btdc max lift 110 deg btdc duration 218 deg |
Re: scored my engine :)
sweet, put a blower on it
ΜΟΛΩΝ ΛΑΒΕ |
67-72 Addict!
This sounds like your cam: http://store.summitracing.com/partde...7&autoview=sku
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Weekend Warrior
I would say it's this cam provided the information you outlined (oops I thought the link above was for something different..it's for just the cam, this one is for the cam/lifter set):
http://store.summitracing.com/partde...2&autoview=sku Decent all around street cam. Depends on what compression ratio you will end up with and what heads your using etc. Is there a part number on the pistons?
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-27-2008 at 06:20 AM. |
Real Projects never die
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
ok so yea pretty decent parts all around
Gone to greener pastures
![]() Join Date: May 2007
Sounds like you got the "bargain of the week" (as a local grocery chain used to advertise) on that motor.
Congrats.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Sounds like a good deal to me. Add a nice flowing set of heads, intake, carb, and hot distributor and you'll have a healthy little motor.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
You didn't mention rods but I will assume they are already on the pistons. What they do to balance pistons and rods is take the weight of the lightest piston, rod, rings, and bearing then make all the assemblies match that weight
69 Chevy 4x4 383 Power ![]() |
On the fast track to nowhere..
What a deal! Congrats!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#13 |
Weekend Warrior
Summit says they have a + 5cc
Federal-Mogul says - 5cc (which is close if they have 4 valve reliefs) http://21cgt.com/FMWebCatalog/default.htm @ -5cc with an .041 Head gasket & .010 Piston in the hole calculations and a stock stroke of 3.48: 64cc Head would be around 10.1:1 76cc Head would be around 8.9:1 I would be inclined to go with a 76cc head and have it milled .010 or so to get you into the 9.2-9.4:1 range. This is a cool little tool, I would say that it is pretty accurate - http://www.angelfire.com/fl/procrastination/motor.html
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-27-2008 at 06:30 PM. |
#14 |
i happen to have 76 cc heads already, a set of nice flowing headers, a edlebrock performer rpm intake, and a holly 750 double pumper
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p. ![]() 70 c10 auto 350 build here Last edited by berencam; 03-27-2008 at 08:37 PM. |
