View Poll Results: Which should i do?
Fix brake line and bleed brakes 0 0%
Completely overhaul brakes (Drums, shoes, new brake line to fix cracked one) 1 100.00%
Voters: 1. You may not vote on this poll
Old 03-27-2008, 06:17 AM   #1
ed2552
ed2552's Avatar
Brake Parts for 67 K10
Where can i find brake parts for my 67 K10? Should i just fix what is wrong, which is a cracked brake line (i believe), or should i overhaul the whole braking system w/ a new Master Cylinder, Drums, shoes, etc, and fix my brake lines?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-27-2008, 06:35 AM   #2
CRUE's 67 LWB
Re: Brake Parts for 67 K10
I just bought all the brake parts for my 67 from Car Quest.
CRUE's 67 LWB is offline   Reply With Quote
Old 03-27-2008, 06:39 AM   #3
ed2552
ed2552's Avatar
ok, so local parts stores. I kinda want to support the board vendors, who has those parts? Most only carry C10 parts, not K10
Old 03-27-2008, 06:49 AM   #4
El Jay
Gone to greener pastures
I usually go to my local CarQuest, or NAPA stores.
The parts are usually in stock. And if not, they're usually in @ the store opening the next morning.
As for your other question(s), I'd open the job up & see what's needed before buying parts.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-27-2008, 06:49 AM   #5
CRUE's 67 LWB
Supporting vendors from the board is great.
But if I get home and my shoes are not right, I can run right back up there. Or in my case have them drive a different set to my shop.
K series parts shouldnt be any harder to find than C series.
Old 03-27-2008, 06:55 AM   #6
wibilly
wibilly's Avatar
i agree see what you need and buy localy you can be on the road in no time
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-27-2008, 06:56 AM   #7
ed2552
ed2552's Avatar
but the front drums have a huge hub on them, which i'm probably going to upgrade to a Warn or similar unit, just for better looks, ease and security
Old 03-27-2008, 06:57 AM   #8
ed2552
ed2552's Avatar
I will try my local parts stores
Old 03-27-2008, 06:59 AM   #9
ed2552
ed2552's Avatar
Would NAPA and the like carry the lines?
