Late model wheels on my 69 c-10
My coworker bought some bling bling wheels for his late model chevy. Old wheels and tires have 2000 miles on them. He wants $300 for a set. I am sure that he will take $250. I took one wheel home to see if I will like it or not. Bolt pattern is fine but the hub is too big. Also, rear wheel will not clear. I can probablly get some wheel adapters but that will add $100 or so. What do you guys think should I pass or buy them? Thanks
Re: Late model wheels on my 69 c-10
I say pass, the wheels you have are probably better looking than those
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
so easy a caveman can do it...
![]() Join Date: May 2006
Fixed
Insert Title Here
if they dont fit then pass... i wouldnt spend more money to make them fit
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 03-27-2008 at 07:03 AM. |
its all about the +6 inches
if you have rims to put the tires on, then go for it.
Personally, even with spacers to 'fix' the hub hole and back spacing issue, I'd personally still think they look like crap on a classic. |
there not bad imo!
R.I.P. Killer 71 10/26/07 |
Agree 100%, the tires are worth at least that, it is a good deal, just don't use the rims, sell them to a dealer or a body shop. When a car gets hit in the right spot, it bends the rim and it is shot, and if they buy them from you for, say $50 apiece, that is cheaper than getting them from a GM dealer for 100 or more, or they could use them to put on trucks about to get painted, and they wouldn't have to worry about overspray
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A Last edited by ed2552; 03-27-2008 at 07:09 AM. |
i agree on passing those rims add a flimsy look to your truck
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Questionable
i'd say pass if you're thinking about buying them to put on your truck. you can get four nice wheels for $65 each from Summit like these:
http://store.summitracing.com/partde...5&autoview=sku
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Step Brother
Yeah what he said....
Seriously, they look odd, I would pass. But it's your truck, what do YOU think? |
They look better with a center cap and lugnut covers. If it was a bolt on deal I would keep them.
#13 |
pass for sure.....
1997 GMC Sierra Ext 1965 Mustang |
