![]() Join Date: May 2007
Smart Folks Need Help? repop gas tank issue
So I bought a repop gas tank because mine was ruined. I new the neck was different but the old tank was shot. I didn't keep the old tank cause it was rotten and I didn't think I needed it. Well since then I've figured out the preffered method of installing the new tanks correctly is to take the old neck off and have it soldered or welded on the new tank. I put an ad on the board for the neck off of a used tank but no takers. So this is where I need yall smart folks what options do I have. Can I safely run a fuel hose between the frame rail and bed. I think I can cut the neck of shorter. Then go get some specialty oil/fuel hose from the Hydraulics place down the street and get something that would flex in there.
But I wanted to run this by the smart people -Thanks, Jason
- Jason ![]() ![]() |
Re: Smart Folks Need Help? repop gas tank issue
Jason, I went to a Rubber Distributor in town, they are called Delta Rubber. They may have stores in other locations or maybe even a website. They have a marine grade fuel hose the exact dimension for our Blazers. The fuel hose has wire wrapped inside to keep it from collapsing. Much like some radiator hoses. This is what I'm using. I have not put any miles on my Jimmy since installing this so can't say how long it will work or if it will rub through. I think I bought 3ft for like $28.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Thanks 71jimmy Did you cut down the neck any? Anyone else got any ideas? TTT
![]() Join Date: Jan 2007
He tossed his old tank....
FNG to resto/mod world!
As long as you protect the hose from getting cut or rubbed, go for it. My 92 truck has a rubber filler neck & I put a 3" body lift on & it came with a extension piece you splice into the rubber hose. Works good. I think it'll be allright. If you're not comfortable with the rubber hose, I'm sure you can find a fabricator who'd make a hardline for your tank. Any welder would probablly do it since it's a new tank & never had fuel in it. Might be hard if you can't bring the whole rig in to see how it routes. You might find a tank in a junkyard & as long as the filler is in good shape, you're golden. Good luck!
71 GMC Jimmy - under construction 75 GMC K25 Sierra Grande - under deconstruction 92 Chevy K2500 ECSB - sold 04 Nissan Titan ECSB Off Road - sold & missed 13 Ford F-150 Ecoboost (work truck) - sold 16 Ford F-150 Ecoboost (work truck) ![]() |
i dont know how long it will last but i have used a piece of galvanized exhaust pipe i got from a muff shop on an old tractor i had it has been on there almost two years and has not fallen off or rusted off yet
used it for a filler neck extension so my dad wouldnt have to lift the old heavy hood to put fuel in it it could be bent real nice and welded if you can make the sizing work |
If you can wait till the snow pack melts up here, I have a tank in a parts blazer I'd cut up for you.
All I'd ask for is shipping. ![]() |
Just had the same issue on my Blazer. 22 inches of NAPA fuel hose does the trick. Stuff's expensive though $19 and some change.
CPO U.S. Navy(Ret) 1972 GMC Jimmy 4x4 Custom 1972 GMC Jimmy 2x4 Custom |
#10 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Kurt If I send you a hairdryer to thaw that snow do you think you could have it to me by tomorrow.
The hose I used was GOOD hose, thick and wire wrapped in the middle. Went from the tank to an elbow that I had to make to go up then to the fuel fill. Worked great. The hose I used was Gates hose. The distributor only had one hose for the size I needed. link below shows similar, It is heavy duty.
Ron http://www.gates.com/brochure.cfm?br...cation_id=3202
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#13 | |
#14 |
Post Whore
![]() Join Date: Feb 2000
Here are a couple pics I took this morning to show how I used the old tank's filler neck. About a 4" piece of hose goes from the new tanks existing filler neck and attaches to the bent piece that I cut off my old tank, then it connects to the long piece that will go up the side of the Blazer.
![]() ![]() ![]() The rubber hose is 1 3/8" id so you ought to call an exhaust shop and see if they have access to any exhaust tubing with an outer diameter of 1 3/8". If so, just have them bend you up a curved piece and slap that in to get you going. Here is a pic of my old tank. I cut off to about 1 1/2" behind that little tab that you see on the side of the filler neck. For reference, you can see how I folded that tab flat in the first two pics. ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 03-28-2008 at 05:57 PM. |
