Old 03-27-2008, 06:57 PM   #1
danomano
Key will not go to ACC.
Anyone know how to fix the key cylinder so it will move back to acc? This is in a 87 suburban.
danomano is offline   Reply With Quote
Old 03-27-2008, 10:02 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Key will not go to ACC.
I had a worn out lock cylinder in one of my trucks that did the same thing. Eventually it jammed completely and I had to replace it. Replacing it with a new lock cylinder cured the problem.
Pyrotechnic is offline   Reply With Quote
Old 03-27-2008, 10:03 PM   #3
1974k5blazer
Just replace it get a steering wheel puller from auto zone and buy an ignition and key while your there, they are only like 20 bucks, with the key, slide the old one out, put the new one in, put the steering wheel back on and your done!
1974k5blazer is offline   Reply With Quote
Old 03-29-2008, 05:06 PM   #4
87 dually burb
my short bus
87 dually burb's Avatar
cool my 87 does the same same thing wont lock in off and no acess
doesnt need a key to start but not good around the kids either
glad i found this post
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 03-31-2008, 03:47 AM   #5
danomano
Did the cheapo fix and sprayed a ton on WD40 works great now!
Old 03-31-2008, 10:55 AM   #6
Mkcustums
Mkcustums's Avatar
While it was still in the column? Sounds messy!
Mkcustums is offline   Reply With Quote
Old 03-31-2008, 06:08 PM   #7
danomano
Put some paper towels under it to catch drips!
Old 04-01-2008, 02:25 AM   #8
Mkcustums
Mkcustums's Avatar
Just giving you a hard time is all.
Old 05-13-2008, 11:37 AM   #9
jimfulco
Did you try pushing the key inwards or upwards or both while you were turning it? Or jiggle it a bit while you turn it?
jimfulco is offline   Reply With Quote
Old 05-15-2008, 06:21 PM   #10
danomano
Fixed it with WD40. Works like a charm
