Old 03-28-2008, 06:26 AM   #1
Ilike 72"s
speed warning dash???
What does a speed warning dash look like? I just drug home a truck that has a white pointer at about 55mph. I don't see how to move it.
Ilike 72"s is offline   Reply With Quote
Old 03-28-2008, 06:30 AM   #2
teeitup
Just like to part out trucks!!
teeitup's Avatar
Re: speed warning dash???
Here ya go, see the dial up by headlight switch
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-28-2008, 06:35 AM   #3
Ilike 72"s
THANKS. Thats it. Although I didn't see the knob by the light switch, it must be there. How does the knob control the indicator? Cable??
Old 03-28-2008, 06:59 AM   #4
teeitup
teeitup's Avatar
Its a cable that loops into speedo, then there should be a wire that hooks to back of setup on tin and then it connects to back buzzer mounted on inside firewall then to fuse box
1980 chevy swb 4x4
Old 03-28-2008, 07:09 AM   #5
drivethechevy
drivethechevy's Avatar
what trucks are those found in?
ive never seen one before
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 03-28-2008, 03:16 PM   #6
ed2552
ed2552's Avatar
It was an option on our trucks
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-28-2008, 05:56 PM   #7
69halfton
69halfton's Avatar
...so does its buzz or light up a light?
..im assuming its basically just supposed to annoy the driver.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-28-2008, 06:08 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it was optional on trucks... 69 was the last year for it though. It was more common on the bigger trucks.
A buzzer goes off, and it's kinda there to annoy the driver, but it's there so you know you are going X mph. You'd simply set it for 5 MPH over the speed limit, and you'd know when to let off the gas.
Old 03-28-2008, 08:36 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
I have heard it was more common in the bigger trucks, but have never seen one in a bigger truck. I have only seen a few of these IN TRUCKS FROM THE FACTORY. 2 were 1/2 tons, and one was a 3/4 ton camper special.
I just used CAPS to clarify that these were factory optioned trucks. (anyone can add one)
Andy is correct on 69 being the last year. I believe the cruise control took the place of this. Nice find either way! I am sure it would look good hanging up in my basement. HA, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-01-2008, 07:20 AM   #10
Ilike 72"s
ERIC. I PM ya.
