3'' body lift?
how hard would it be to install a body lift on a early to mid 80s gmc with an 8'' suspension lift already in place? and what kind of kit should i look into getting to do this with? thanks for the help may be done this summer if i do go ahead with it.
A.J. ![]() 1970 Volkswagen Beetle- Tribute to the Cal-Look cars of the '70's (Restoration Started)(For Sale, Make Offer) 1997 051-F droF Teal Clear Coat (OG Paint, 12 Years-Old) AIR FORCE Brat, 6-11-'86 to 2-1-'94 ![]() |
![]() Join Date: May 2007
Re: 3'' body lift?
Just have to pay attention to things like the fan shroud,hoses,shifter linkage,steering shaft.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#3 | |
Re: 3'' body lift?
use a couple long wood 4x4 on a couple floorjacks and lift away. The ones that summit sells are pretty good. |
Re: 3'' body lift?
i forgot to mention that its an automatic trans and has 38.5'' tires on it already. and the suspension parts are superlift.
Re: 3'' body lift?
The suspension lift will not effect the body lift at all as far as installing it.
As mentioned you just have to look-out for and adjust the hoses and wiring (especially grounds). You have to deal with the fan shroud, most guys just remove the bottom half....I don't recommend that, you really need to make some kind of extension/lower it/ something better than just taking it off. The transmission shifter needs to be cut and an extension welded in. The only real variable here is the transfer case...You didn't specify the year, so it could be a few chioces there. 203s and 205s have the shifter mounted to the case itself, which makes it drop into the floor by 3". The 208 t/c has the shifter mounted to the floor of the cab. It doesn't change anything from the inside of the cab, but you will have to adjust the linkage for that too. I have always done it by jacking up one side at a time. There is a "balance" point right around the door hinge area (as far as front/back ratio) where you can jack it up from a single point. As long as you have access to a welder/weldor, the whole job can be done in a few hours. |
New Member
Re: 3'' body lift?
It is pretty straight forward. The one thing I forgot about when I put one on a 77 I had was to disconnect the hose between the bed and the gas tank.
Re: 3'' body lift?
heres an ok picture of it. ill get better ones the first of june when i go back up there(Indiana).
