Junior Member
![]() Join Date: Feb 2005
Change front hubs to narrow on dually?
I've got the 78 GMC Dually chassis under my 50 GMC Bus. The front end is just a little wide. I plan to lower it with bags or spindles.
I can widen the front fenders from the inside edge about 2 inches. Does anyone know of a different hub that would bring the wheel in just a bit? I discovered that as far as the rear goes, I was able to use a Commercial dually rear end. It was 8 inches narrower, but used the same spring perches! I'll post pics later. John Last edited by BBEEP; 03-29-2008 at 06:16 AM. Reason: GRAMMAR |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Change front hubs to narrow on dually?
Use the standard 3/4 ton rotor with the dually rim. They do it all the time over at www.duallyscene.com. That way they can tuck their front wheels on thier bagged duallys.
#3 | |
So how would u run the stock dually rim in front? |
Junior Member
So, here is how its done: Use 1-ton NON-dually front hubs. They bolt on and are the correct depth (width). The problems is the 16 inch wheels won't wrok because the calipers hit the wheel--at least on my Alcoa's. A P30 Grumman stepvan (like a breadtruck or fedex) runs 19.5 inch wheels and some if not most will bolt on. They can sometimes be found for about $50 with tire each.
Sb 400 club
wow i am not much help on this one but can't wait to see pics!! sound slike a cool project
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
It's like Brooklyn said...you only need to do it if you plan on tucking 22"+ wheels.
...and even at that, it's purely optional. You can tuck a 22 with the DRW hubs, the SRW hubs simply allow you a bit more room to turn the wheels while aired out. |
