Pro-Touring
I think im going to do a pro touring truck any suggestions on a rear suspension setup that would provide better handling? I have already decided on the porterbuilt C4 dropmember on the front. suggestions, pictures, website links anything appreciated.
Re: Pro-Touring
CPP i think makes a 2 link rear suspension system -- the stock trailing arm setup is actually really good in back -- but for appearance's sake, you might invest in some tubular or boxed control arms
Are you retired too? Nonsense! I'm in my prime |
Re: Pro-Touring
How about a C5 rear from a vette? Check out FrizzleFry's build.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Aug 2006
Re: Pro-Touring
I think if you are already doing the c4 front i think you should continue it to the rear also. Nothing sexier than a 4 wheel independent suspension
![]() Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: Pro-Touring
Also one more thing. If you are keeping the stock frame i would box it for additional strength in the frame
Re: Pro-Touring
ttt
Re: Pro-Touring
If you look at Pro-touring.com a lot of the guys there will run "truck arms" on their camaro/nova/chevelles as their rear suspension. Well we got that for free. I'm staying with the truck arms on my truck. For right now I'm staying with the stock front setup (except for airbags and adjustable shocks) and probably bigger brakes. I may later play with moving some of the arms around to get better geometry (such as the guldstrand mod for 1st gen camaros) but I haven't spent enough time thinking/measuring/and calculating to put anything into action.
C10 addict
Re: Pro-Touring
Also check out lateral-g.net. There is some good info there that you might find helpful
