Old 03-29-2008, 05:52 AM   #1
MisterE72
Keep Your Nose Clean
ECE super track bar and finned aluminum diff covers.
Greetings folks,
Its been a few weeks since my last post, so i'm overdue. I'm ready to have the GM 12 bolt reassembled now, but I want to install one of those cool cast or aluminum covers. I heard you can't run those on our trucks because they hit the track bar. Since i'm going to run a ECE super track bar kit, will that allow me the space to run the finned diff cover? Show some pics if you got'em. I dare not ask for pics of "your rear ends" because the last time some of you guys traumatized me. Thanks for any help you can provide. Mr.E
MisterE72 is offline   Reply With Quote
Old 03-29-2008, 05:55 AM   #2
ed2552
ed2552's Avatar
Re: ECE super track bar and finned aluminum diff covers.
My "rear end" would break the camera!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-29-2008, 05:58 AM   #3
AGRV8D
Regular Confuser
AGRV8D's Avatar
Lmao
My Stuff
Surgeon General never said anything about smokin' Fords.
Build Thread
AGRV8D is offline   Reply With Quote
Old 03-29-2008, 06:00 AM   #4
fastom
That's right, it's Copper!!
fastom's Avatar
I haven't found a cover other than the stock style that works with the ECE bar.
fastom is offline   Reply With Quote
Old 03-29-2008, 08:05 AM   #5
Alex Hayley
I am going through exactly the same situation. Since I don't know exactly what cover you are using, you will have to determine if the track bar will not clear the cover. If it does not clear the cover, ECE has just come up with a new track bar that is bent in such a manner that it will clear a deeper cover. You can phone Stan at ECE to find out the specifics of the track bar. If you just want to order it, you can add the super track bar, albeit straight, to your cart. In the special instructions for the order, state that you want the BENT super track bar. Let us know how the bar fits!
Alex Hayley is offline   Reply With Quote
Old 03-29-2008, 02:26 PM   #6
The ECE Super Track Bar will sit in the exact same location as a stock track bar.
Old 03-29-2008, 08:57 PM   #7
Alex Hayley
special-K, if this is a reply to my post, the track bar I was referring to is a NEW track bar that bends around a deeper cover. If it is not a reply to my post, ignore this post.
Old 03-29-2008, 10:44 PM   #8
Hart_Rod
Hart_Rod's Avatar
I bet it will be close, since it is close with the stock cover. Here are some pics of my 67 CrewCab.
Hart_Rod is offline   Reply With Quote
Old 03-29-2008, 11:27 PM   #9
Alex Hayley
Here is a picture of the interference I had. Granted, it is not a super track bar but you can see just how close things will be.
Old 03-29-2008, 11:33 PM   #10
67c-10Texas
here is what i am going through - no solutions yet but i have not been working on the project lately
http://67-72chevytrucks.com/vboard/s...d.php?t=273701
67c-10Texas is offline   Reply With Quote
Old 03-29-2008, 11:38 PM   #11
Number98
Prestige Worldwide
Number98's Avatar
CPP makes a bent one to clear "taller" rear covers. There was an artical about it in either Classic Trucks or Custom Classic Trucks a few months back. I ordered one because I have a Trick Flow cover with the bearing cap support studs and the CPP bar did not clear either... It was not bent in the right place so it was going to hit the right side of my cover....
Also I spoke with Stan at ECE a few days ago and he said that they do have one that is bent to clear the covers as well. I had to ask him about them though because they are not advertised.
Number98 is offline   Reply With Quote
Old 03-29-2008, 11:56 PM   #12
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I posted some pics a while back of that setup.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-30-2008, 12:25 AM   #13
71STPSDE
71STPSDE's Avatar
I have the ece track bar and it hit the T/A cover I bought. I had to go back to stock. I posted the same question a few months ago. They look alot nicer that stock.
71 Chevy Stepside
377/350
71STPSDE is offline   Reply With Quote
Old 03-30-2008, 04:42 AM   #14
TR65
TR65's Avatar
Check out this post, similar question and lots of pics.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
