Old 03-29-2008, 09:04 AM   #1
Pont406
Does anyone run a powertrax?
I am changing rear gears. For now I will keep it open diff. Next week I will order a powertrax unit http://store.summitracing.com/partde...5&autoview=sku. Who is running one and how do you like it? I might get 15X10 rally wheels for the back. I have 2 years old tires from my car. I think tires will clear with the right backspace. I am planing to visit a dodge boy in 2-3 weeks.
Pont406 is offline   Reply With Quote
Old 03-29-2008, 03:20 PM   #2
70GMCer
70GMCer's Avatar
Re: Does anyone run a powertrax?
I have one setting on the shelf in the garage ready to go in. There's been some comments on these. Most complaints I hear is the clicking noise it sometimes makes when turning. The way I see it, if you have a loud exhaust, won't matter anyway. I still plan on installing mine as soon as I finish the disk brake conversion.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-29-2008, 04:04 PM   #3
ed2552
ed2552's Avatar
What gears are you putting in?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-29-2008, 07:55 PM   #4
chevguy7
chevguy7's Avatar
I have heard some complaints too. One of my friends has one in his '71 nova and likes it. How durable are they?
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 03-29-2008, 08:37 PM   #5
68 short step
im useing the no-slip version in my 68.... i have yet to drive my 68, and hear how loud/quiet it is, but it is suspose to handle 450HP...
68 short step is offline   Reply With Quote
Old 03-29-2008, 10:13 PM   #6
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
I rebuilt the differential in my 71 a few years ago and put in a PowerTrax with new 3:73 gears and I really like it. Although the truck has been driven very little because I haven't finished working on it yet, I am pleased with the end result. I can verify the clicking can be a little loud at times but I bet it will quiet down once the unit wears in a little. I think it works better than a posi does.... You won't be dissapointed for the money... It's a great upgrade for any truck provided it isn't driven on ice!!!!
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 03-29-2008, 11:19 PM   #7
cruiserman
If it doesn't click, something is broken .
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 03-30-2008, 01:41 AM   #8
straitnate14
straitnate14's Avatar
I have one and at first it would unlock but I when I looked inside it was the thrust washers. they where worn out and to thin so when I put new ones in witch are a pita to find I got 10 extra sets I had to order 20 washers to get the dealership to get them and I ended up takind a 45 min trip to get so a a diffrent dealer because I couldent wait if anyone needs them, but after I got the new set in it works great
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 03-30-2008, 02:41 AM   #9
68 short step
Old 03-30-2008, 02:59 AM   #10
Lated
Lated's Avatar
Will one of these work in my stock 12-bolt. I'm not sure if the "Axle Model: GM 8.875 in., truck" under the application tab on Summit was the same as a truck 12-bolt which is all I've ever heard it referred to as.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 03-30-2008, 03:07 AM   #11
duane67c-10
duane67c-10's Avatar
i have a powertrax in my chevelle, mine only clicks once when you put it in drive and then when you turn, but other than that i love it!
duane67c-10 is offline   Reply With Quote
Old 03-30-2008, 03:08 AM   #12
jlaird
jlaird's Avatar
yes, our truck 12 bolts are 8.875"
In making the decision, just realize you can get an eaton posi for $364 bucks at summit. The will match the lowest price on the net which is here: http://www.rearendparts.com/home.php?cat=149
jlaird is offline   Reply With Quote
Old 03-30-2008, 03:28 AM   #13
chevguy7
chevguy7's Avatar
How easy would it be to swap in the eaton posi compared to a powertrax?
Old 03-30-2008, 03:30 AM   #14
Lated
Lated's Avatar
Sorry for the thread hijack but what's the difference between the 3 and 4 series carriers?
Old 03-30-2008, 03:49 AM   #15
redhead69
fugedaboutit
redhead69's Avatar
I broke my no-slip unit on the first pass it made down the track. Im sending the unit into to richmond for a warranty inspection and hope its covered. If they dont refund me and just exchange with a new unit i will post it up for cheap. I really think I had a bad unit because im right under 400 hp and was professionally installed (which isnt saying much). Anyway I went to a mini spool because I had one laying around.
One thing to consider, and this is what some guys at the track were telling me and not my experience, but when you pull into a box and do your burn out.. sometimes only one side will lock up, then you go up to the light with 1 wet tire and when you launch the wet tire will lock and spin. Just my experience with it and will keep you all informed about the warranty deal so we know how richmond is about that
eric
Currently truckless
redhead69 is offline   Reply With Quote
Old 03-30-2008, 03:50 AM   #16
redhead69
fugedaboutit
redhead69's Avatar
the powertrax requires on ring and pinion set up.. so much easier
Currently truckless
Old 03-30-2008, 04:11 AM   #17
jwalk
What was I thinking?
jwalk's Avatar
i had one in a 67 long bed 3.73 small block around 400 hp 420 tq and it lasted about 5 months i was kinda hard on it but all the pins broke so i went with a detroit unit and i have had it in my daily driver for 4 years now same motor no problems i know it cost more but you get what you pay for
jwalk is offline   Reply With Quote
Old 03-30-2008, 05:21 AM   #18
Inherited71
Inherited71's Avatar
I put on in my 71 felt good at first. It would lock one side then unlock the other. Came back home pulled the cover cheked it all out looked good. Found out that air pressure in the tires were off (slicks) matched them up drove it around felt good. Stoped in the road Stalled it up and let it have it felt awsome till the thing Ulocked or if you will disengaed BOTH sides hit the high side chip @ 6800 RPM. Oh on the way home locking and unlocking. Called Eaton told them what was happening and did I do any thing wrong during the install they said no.(went through the install process) They said to return it. So I called summit and all is well. Eaton did ask how much power I was making & I said about 550 or so the first thing he said after that was send it back. So my recomendation would be a spool or a POSI. This is just my experience.
Inherited71 is offline   Reply With Quote
